H3 stuck in 4 wheel drive high
Old Jul 14, 2010 | 05:29 PM
h3gashog's Avatar
Default H3 stuck in 4 wheel drive high
I have a 2006 H3 5 cylinder (I hate it too) with 62,000 miles and sometimes it sticks in 4 wheel drive. When first started it will run a few minutes in normal 4 wheel drive then I notice a change in the steering as it goes into 4 WD high lock. I have tried cycling in and out of 4 WD high and low while in neutral as well as driving backwards in circles in 4 WD high as suggested by another post on here but to no avail. I have also noticed when in 4 WD low lock that it makes a whining noise from the front passenger side? Any help would be greatly appreciated!!
2006 H3
1998 BMW M
2002 Ducati 900SS
Old Jul 14, 2010 | 09:40 PM
2wheelmonster's Avatar
I don't hate my H3
Old Jul 14, 2010 | 09:46 PM
JGBB04's Avatar
check & clean the buttons alot of people have had them stick. also could be the plastic shift fork issue in the TC if that hasn't been fixed already
Old Jul 15, 2010 | 12:08 AM
Manson75's Avatar
from what I've read on this forum, I'd say it's the plastic shift fork also. Either in 2007 or 2008 they were switched out with aluminum ones because of their common failure. Search "shift fork" on here to see how you can get it fixed.
Old Jul 15, 2010 | 12:28 AM
drtom's Avatar
Banned
the day i dont love my h3 ill sell it cheap
Old Jul 15, 2010 | 12:46 PM
h3gashog's Avatar
Default I don't hate my hummer I hate the 5 cylinders
Thanks to everyone who posted replies!!!
Old Nov 14, 2010 | 11:30 AM
raycraftoncape's Avatar
Thumbs up Plastic Shift Fork
Thanks everyone for your posts you certainly pointed me in the right direction and saved me a lot of $$$$. Had my vehicle checked by a Hummer technician and to no surprise it was the plastic shift fork. I even talked to GM and they paid 50% of the repair under their good will program since it was out of warranty. Mileage when problem occurred 57,000 Miles.
Thanks again
Old Nov 14, 2010 | 12:18 PM
MarkMc00's Avatar
Does the shift fork do its thing only when shifting between 4WD modes, or does it work during normal shifting? What I'm trying to determine is the likelihood of it breaking if your rarely or never switch between 4WD modes. Hope this makes sense.
Mark
Old Nov 15, 2010 | 06:05 AM
Default Shift Fork
Mark,
Its not a matter of if its a matter of when! It will wear with out you switching in and out and eventually break. Its a bad design on hummers part and they are well aware that's why they changed the part to aluminum.
Old Nov 15, 2010 | 09:10 AM
drtom's Avatar
Banned
Default recall
should be a recall or fix free for life.
the real problem is the damage it causes if not detected early,tran,t case,?
