H3 Stock Radio Question
Old Oct 26, 2011 | 04:04 AM
  #61
Broken Halo's Avatar
Don't use my OnStar so not sure, but I think it only uses 1 channel/speaker, not stereo.
Old Oct 26, 2011 | 04:19 AM
  #62
drtom's Avatar
Banned
on the radio conn 2,pin j is left,pin h is right, pin k is shield. you know me, i never type b4 i check facts!
that audio would only be heard when onstar is active?. dont know how it gets done,or how it tells the radio to take it
Old Oct 26, 2011 | 09:38 AM
  #63
moho's Avatar
drtom, I will try it out when I got really bored some day. Do you have a diagram of the radio conn 2?
Old Oct 26, 2011 | 11:12 AM
  #64
drtom's Avatar
Banned
u can download the entire manual for 10 to 15 bucks.
look for hummer service manual
Old Oct 27, 2011 | 04:36 PM
  #65
kurteken's Avatar
Hello,
Is it possible to change the frequency of the radio by one step at the time?
I mean, now it jumps for example from 91.3 to 91.5 to 91.7 and so on.
Where are the 91.2, 91.4, 91.6??
Is it even possible??
Thank you
K.
Old Oct 27, 2011 | 05:32 PM
  #66
drtom's Avatar
Banned
it just follows the channel spacing,,so it goes with new tech "progress",no analog tuning no mo
Old Oct 27, 2011 | 09:39 PM
  #67
Originally Posted by kurteken
Hello,
Thank you
K.
Hey K.
I know you are in Belgium and they use the same FM channel center frequencies ending in 0.1, 0.3, 0.5, 0.7, and 0.9 megahertz (ODD MHz), some countries use "ODD MHz" channel center frequencies as well as channel center frequencies ending in 0.0, 0.2, 0.4, 0.6, and 0.8 MHz (EVEN MHz).
So unless you travel to those "other countries" you will have no need for the "even MHz" channel center frequencies.
Old Oct 29, 2011 | 03:54 AM
  #68
kurteken's Avatar
Hello Tainter,
Thank you for the info, but some radiostations i like to listen to are just like 99,4Mhz :-(
I can listen to it but it is not clear.
Bye,
K.
Old Dec 19, 2011 | 05:37 PM
  #69
58Bisc's Avatar
The radio pin outs are different for the H3 vs. the vett. I've spoken to Ray and he can create the short piggyback cable that will allow you to plug it directly into the back of the radio. It has a short jack cable that can be run to one of the aux light dummy plates in the cover if you don't have that option. It is an H3 version of his AUX-3 option. Seems like less work then the XM plug since it is a much shorter run and you only have to remove the radio console cover plate to get to everything. It is not a radio controlled iPod option like a PAL unit, but it will allow any audio device like a MP3 or iPod to play in true digital and it works with the Monsoon option. Not as cheap as splicing into the harness yourself, but you don't loose XM and it can be removed if the need ever arises.
Mrr2006H3
May 23, 2012 08:31 AM
jadyejr
Apr 1, 2011 11:30 PM
Peterje9
Oct 27, 2010 05:18 AM
kosaic
Sep 24, 2007 05:11 PM
Dennis
Mar 17, 2006 11:08 PM
