H3 rough idle after plug change
So I've read up on past threads. I see that ONLY OEM plugs are recommended. But maybe that's not my issue? Replaced OEM plugs with NGK over the weekend, they look identical to stock. Noticed that there is a wire track that is in the way of the first coil in the line. Made it tough to get the coil off and back on. When I reinstalled the coil on this one it seems like I was forcing down rubber to get it bolted back on (maybe a centimeter gap instead of being flush). I am suspecting this is the cause of my issues and not the NGK plugs. How to you get that wire tract off so it's out of the way and I can get the coil back on properly and do further testing?
Going to reseat the C.O.P. on the first cylinder, where I was having an issue with the wire tract.
These were pre-gapped NGK plugs and I verified that they are gapped to .40.
So what really are the OE plugs? Partsgeek is telling me Iridiums?
http://www.partsgeek.com/catalog/200...park_plug.html
Work great on my supercharged AMG! Okay I get it... I5 started up like a lawnmower, so even if one coil pack was not seated properly it was very rough. I'll try the AC Delco plugs I can buy locally.
