h3 roof rack
Old Aug 22, 2012 | 06:46 AM
  #21
stix00999's Avatar
Default looks great!
Thanks for adding the pics - rack looks great ! a great compliment to your rig!! I "borrowed" some of your original pics for a fabrication guy who I am working with form something similar. If it works out, I will post some pics.
Did you use bolts only in the tracks or did you have a machined block (like Gobi)?
Thanks again for the update.
Old Aug 22, 2012 | 08:14 AM
  #22
58Bisc's Avatar
He did the opposite of GOBI and gave me blocks with threaded rod welded to them. They slide in the channel and the rods stick up. I used acorn nuts to give it a more finished look. Make sure your builder understands that the H3 roof is not flat. If he makes the rack flat, the the mounting braces in the front and rear should be longer and the ones in the middle should be shorter. If not, he should curve the main rails.
Old Aug 23, 2012 | 11:54 AM
  #23
58Bisc's Avatar
Here are a couple of pictures! Hope they help...
Channel brackets in channel (I replaced the flat nuts with acorn style):
Front, also prior to trimming the pad:
Old Aug 24, 2012 | 01:57 PM
  #24
stix00999's Avatar
great - Thanks !! - already have these printed off for the FAB guy...I was considering using the same tubing as vertical risers instead of the plate..more like a "factory" look
ddupreyjr
Feb 6, 2015 07:01 AM
DennyOK
Oct 31, 2012 11:01 AM
Caraddict
Apr 22, 2011 07:13 AM
Theuofmiami
Aug 29, 2010 09:20 PM
FloridaFeMan
20
Feb 18, 2010 08:19 AM
