H3 Performance Ignition coil
Old Oct 19, 2012 | 08:46 AM
Hummer_SG's Avatar
Default H3 Performance Ignition coil
Hi all.
Does the V8 ignition coil same as the 3.7 h3 ?
Other than accel ignition, is there any other plug n play ignition coil?
Thank you.
Mike
Old Oct 19, 2012 | 10:01 AM
I deleted your duplicate post.
The I5s use coil on plug packs, the LH8 uses two banks of coil packs, 4 on top of each valve cover, with short straight wires including heat shielded boots to each plug. No distributor.
There are aftermarket coils. What are you trying to accomplish?
You can get a bunch of ponies out of the LH8 and the stock coils are no limitation. Building performance with these motors is different than back in the day, so unless you just want some pretty red ones, if it ain't broke don't fix it. You can also get replacement wires as well.
Old Oct 19, 2012 | 11:09 PM
Great picture Doc, I'm going to "borrow" that one.
sagev
Jan 17, 2013 11:41 AM
Caraddict
Dec 12, 2011 06:55 AM
Hummer_SG
May 25, 2011 12:40 PM
h2_32137
Jan 29, 2010 12:07 AM
Mikeoj338
Aug 19, 2008 10:43 AM
