H3 Leveling Kit
Old Aug 6, 2006 | 06:31 PM
  #51
Linus Gump's Avatar
Default RE: H3 Leveling Kit
Under the text window where you type it says, "Click here to upload!" in blue. Click there and find the pic on your hard drive. If you click in the box next to the blue writing, it will put the picture in your post. Otherwise people have to open it as an attatchment.
Old Aug 9, 2006 | 08:27 PM
  #52
HummerGuy's Avatar
I adjusted it last night. The bolts are very easy to adjust. I did one complete turn on each side. It raised it a little, but the difference is really in the handling. The front end seems tighter, and the H3 does not sway as much on a turn as it used to. I can definitely tell there is a difference, even though not dramatic. I may give it another half turn or so before I leave work today.
Old Aug 9, 2006 | 09:16 PM
  #53
dilo2001gt's Avatar
Just buy the new keys thats the best way.
http://cgi.ebay.com/ebaymotors/2006-...spagenameZWDVW
[IMG]local://upfiles/111/A5D65B9C1AB14A9AB5CC2ACA3716FF37.jpg[/IMG]
Old Aug 9, 2006 | 11:06 PM
  #54
HummerGuy's Avatar
I have seen these on eBay alot but really don't understand where they go or what they do. If I had a factory manual I could figure it out, but just by looking underneath I can't really tell how or where you install these.
Old Aug 9, 2006 | 11:31 PM
  #55
dilo2001gt's Avatar
Middle of the frame you take the factory ones out and replace them with theses.
Old Aug 10, 2006 | 02:14 AM
  #56
madmaxmyers's Avatar
It is a half hour job to replace both of them (especially if you have an air wrench). The keys completly unload when you unscrew the adjusters, so you don't need any tools to hold the tension bar.
Old Nov 17, 2008 | 08:17 AM
  #57
asvinci's Avatar
Default RE: H3 suspension
Has anybody tried the Bilstein Front leveling shocks instead of using a leveling kit? And how doe sthe truck look and ride when done with the install.
Old Nov 17, 2008 | 08:22 AM
  #58
Atwo year old thread? History revisited. [&o]
The forum has a SEARCH feature. Check it out sometime, it actually works.
Search and you shall find. Front Leveling/Shocks & 35" Tire/Wheel FAQ; RE: Shocks
Old Nov 20, 2008 | 08:20 PM
  #59
asvinci's Avatar
I recently just pruchased a leveling kit from Skyjacker. Ill let you how it works out.
Old Nov 20, 2008 | 08:21 PM
  #60
asvinci's Avatar
I recently purchased a leveling kit from Skyjacker. Ill let you know how it works out.
