H3 Alpha tire pressure
Old Jul 7, 2008 | 07:52 AM
mountainbyker's Avatar
Default H3 Alpha tire pressure
Hi guys, I apologize if this has already been asked but I couldn't figure out how to search the forums. I just bought an H3 Alpha, drove it for a couple weeks and checked the tire pressure. The tires state the max air is 44 which is what I put in but shortly after filling them I noticed a factory sticker on the door which said the correct pressure is 31 which is what they were filled to before I started fooling around.What is the correct pressure? It seems like 44 would be better for mpg but I don't want to mess up the tires.
One more question - how do you search the forums??
Thanks!
Paul
Old Jul 7, 2008 | 08:51 AM
HummerMike's Avatar
Default RE: H3 Alpha tire pressure
Recommended tire pressure is on a sticker inside the drivers door jamb. That's the pressure the dealer will set when you have service. I think it's around 35psi depending on your tire size, 32 or 33". 44psi will probably set the tpm system alert on the dash for overinflation.
Old Jul 7, 2008 | 10:06 AM
For the 33s the H3 door jamb sticker says 35psi. I run my H3 with the 33s at exactly 38psi cold for on road driving.
Old Jul 7, 2008 | 10:16 PM
alrock's Avatar
I'm at 38 as well, a bit above the mfr. recommendation. Do not inflate them to the max PSI on the sidewall (not that you would, I've just seen it done before).
Old Jul 10, 2008 | 10:10 PM
Thanks for the tip - why not inflate based on what's on the tires? (I did!)
Thanks - Paul
Old Jul 11, 2008 | 01:10 AM
hummech's Avatar
put the pressure from the drivers door sticker. i would explain why but every time i have tried on this forum it times me out. it has to do with the performance of the hummer and the tire ware.
Old Jul 11, 2008 | 10:37 PM
Midnight Blue's Avatar
I'm at 44psi trying to get some mileage out the H3....and don't care about tire life...it's a lease.
Old Jul 12, 2008 | 09:21 AM
Can you tell if it makes a difference?
psych0
Sep 16, 2010 05:35 AM
razorbackfan
Sep 22, 2006 11:18 PM
importkiller
Sep 16, 2006 11:46 AM
Sugardaddy
Aug 9, 2006 06:36 PM
TIM06H3
Feb 8, 2006 10:00 AM
