H3 5 Speed Towing Question From Newbie
Old Jan 7, 2016 | 06:11 PM
Diggersh3's Avatar
Default H3 5 Speed Towing Question From Newbie
I have a 2006 H3 5 speed manual trans ,base model and I do have a question based on some of the things I see on the forums people are towing with these rigs. Is it ok to run extended periods (like 3 hours or so) pulling a trailer at 3200 rpm (approx) in 4th gear as it requires constant shifting from 5th to 4th towing even my light weight 5x8 V-nose cargo trailer with like 300 pounds in it? If I run in 4th it is fine as far as power.
I have always in the past towed with either v8's or diesels never anything this small. So I am concerned if there is an issue running this little motor that hard . Any information would be great.
Old Jan 7, 2016 | 06:58 PM
happythree's Avatar
opinion, since im not a "tower" and have no stick shift!
4h is direct drive so the tranny should be happy and 3200 wlii just hurt your wallet. and of course wear things out sooner but 3 hrs aint much either.
Old Jan 7, 2016 | 07:20 PM
rsc's Avatar
rsc
No issues with the motor. The tow rating with the 5 speed is lower than the automatic, 3000 vs 4500 lbs. Might want to keep that in mind, especially if you want to run bigger tires in the future.
Old Jan 7, 2016 | 07:50 PM
Diggersh3's Avatar
Great! Thank you for the information.
scubasteve1211
Apr 2, 2012 09:09 PM
08xcab
Nov 8, 2011 08:56 AM
Bohomit
18
Oct 27, 2008 11:46 PM
jockeyshift
Sep 17, 2008 04:54 AM
motley1987
Aug 9, 2008 01:00 AM
