H3 4x4 help needed (not engaging, blinking only)
Old Feb 16, 2016 | 03:36 PM
sbelair97's Avatar
Question H3 4x4 help needed (not engaging, blinking only)
I am having an issue with my 4x4 on my 2006 H3. When the high or low buttons are engaged, all they do is blink then revert back to 4x4 auto. When this is happening, there is a feedback noise coming from the right front speaker. Nothing is engaging. Has anyone experienced this before and if so, what was the fix. I would really like to have 4x4 working again. Thank you in advance.
Old Feb 16, 2016 | 04:14 PM
happythree's Avatar
does it work normal in 4hi,left button? this is 4w/all wheel drive.
if so it should go to 4hi lock even while moving,but do it only off road huh?
4lo you need neutral,slow speed.?
Old Feb 16, 2016 | 04:26 PM
sbelair97's Avatar
yes the left button works normally all the time, only blinks when i try to push the middle or the right buttons.
Old Feb 16, 2016 | 04:54 PM
happythree's Avatar
i dont know if the transfer case actuator can cause that.
someone else will answer soon!!
Old Feb 16, 2016 | 04:56 PM
sounds like the shift fork or the encoder motor is ka-put.
Old Feb 16, 2016 | 05:11 PM
sbelair97's Avatar
Thanks Tainter, I'm inclined to believe that it is probably the encoder motor; whereas if it is the shift fork, I should still hear the gear engaging which I do not hear, correct?
Old Feb 16, 2016 | 05:12 PM
sbelair97's Avatar
I have no codes showing up either so it is a straight crap shoot unfortunately...lol
Old Feb 16, 2016 | 05:20 PM
happythree's Avatar
get a close look at the wiring/ connector on the tr case.maybe you get lucky!!
Old Mar 6, 2016 | 07:44 PM
WR3NCHE4D's Avatar
Here is an option. Remove the motor from the transfer case and with the electrical connected press the 4 hi lock button and the motor should activate and turn. if it doesn't it's the motor. The General has a problem with the motors failing on their transfercases.
Old Mar 7, 2016 | 09:15 AM
650Hawk's Avatar
Yeah, GM encoder motors are notorious for failing. They are also ridiculously expensive, BUT, cheaper aftermarket units will not last. That is one of those parts that is worth spending the extra money on for OEM.
accely
Oct 11, 2014 06:09 PM
BrianDye
Mar 4, 2014 09:35 AM
chopperguytampa
Jun 18, 2013 12:01 PM
markushp
Jul 17, 2009 02:22 PM
Antonio Dom.Rep.
Jun 24, 2008 11:23 AM
