H2 tire pressure
Old Aug 9, 2006 | 12:06 PM
Sugardaddy's Avatar
Default H2 tire pressure
I first searched for this topic but to no avail. What tire pressures do you all run in your H2? Up until yesterday, I had mine adjusted to 37psi, which is the recommended pressure on the door panel. On the side of the tire it says 50psi cold. In my very analytically finite mind, LOL, I figured that a higher pressure would decrease rolling resistance and maybe up my MPG slightly. So I set it at 45psi. The problem now is that the dash board rattles and I don't like the ride. I definately preferred the ride at 37psi, but although it's the recommended pressure, is it too low for the real world? Just want some of your thoughts.
Old Aug 9, 2006 | 02:22 PM
blackstangs281's Avatar
Default RE: H2 tire pressure
Stick with 37 to39. Any higher and you will wear out the inside of your tires after a while........I keep 39 in mine
Old Aug 9, 2006 | 03:05 PM
Sugardaddy's Avatar
Thanks!
Old Aug 9, 2006 | 03:22 PM
Sugardaddy's Avatar
Blkstg281. I graduated from Penn Hills in 1983 with a friend of mine with the same name as your's. Wouldn't that be something.
Old Aug 9, 2006 | 05:07 PM
I graduated from Kitt.......but it's nice to know someone has the same name around here that i could pin stuff on. LOL.
Old Aug 9, 2006 | 06:36 PM
Sugardaddy's Avatar
There ya go.
psych0
Sep 16, 2010 05:35 AM
HEATHERH2
Oct 19, 2006 02:15 PM
razorbackfan
Sep 22, 2006 11:18 PM
importkiller
Sep 16, 2006 11:46 AM
TIM06H3
Feb 8, 2006 10:00 AM
