H2 need help
Old Sep 23, 2012 | 08:47 PM
googie714's Avatar
Default H2 need help
OK need some help, center marker lights front and rear do not work also mirrors work but will not fold in, air compressor not working
2003 H2
thanks
Old Sep 23, 2012 | 10:03 PM
KA H2's Avatar
Check your fuses and relays first.
Old Sep 24, 2012 | 10:20 AM
googie714's Avatar
fuses and relays all good did that first
thanks
Old Sep 24, 2012 | 04:40 PM
Pauldy's Avatar
If you search the forums there are all kinds of issues with the mirrors so knowing what your particularly experiencing is hard to tell. It can be anything from just the motors locking up to the point of requiring total replacements to something as a simple as a loose wire harness.
Do you have pictures of your mirrors?
Old Sep 24, 2012 | 04:43 PM
Pauldy's Avatar
Also for the marker lights, have you tried replacing them? I have an 03 and replaced all mine a few months ago.
Old Sep 24, 2012 | 04:50 PM
Pdmiller's Avatar
my compressor does not work neither do the mirrors-- time to search
Old Sep 24, 2012 | 08:55 PM
googie714's Avatar
Old Oct 7, 2012 | 09:55 PM
googie714's Avatar
all bulbs bad thank you!!!! i,am a dummy
Old Oct 8, 2012 | 10:36 AM
Pauldy's Avatar
NP might want to check gaskets too since you just changed them to make sure there is a good seal still or you might end up with water coming in next.
Old Oct 8, 2012 | 04:54 PM
googie714's Avatar
ok if seals are bad how do you know, where can I get new ones also lost one of the clips that holds the light down where can I get one need help
