H2 Memory seats
Old Mar 18, 2008 | 02:22 PM
Muddydawg75's Avatar
Default RE: H2 Memory seats
When you go through all the options on there you have nothing for the seats?
Just to make sure wea re talking about the same place... I am talking about the programming part where you set the horn beep for alarm, reverse mirrors, easy seat exit.... etc.
Old Mar 18, 2008 | 02:58 PM
finall's Avatar
Correct!
There is nothing in the DIC preference settings for seats that I can find.
Old Mar 18, 2008 | 04:27 PM
I guess they did away with it then.... must be a result of the issues they had with what I mentioned before..
Old Mar 18, 2008 | 04:30 PM
LisaM's Avatar
ORIGINAL: Muddydawg75
What are you set at on the DIC??
Mine is set to recognize the fobs... I don't use the button....
ALSO... there was an issue with the seat programming for some years... I had to get mine redone because forward was back and back was forward and I had no seat memory.
Like suggested check the Fob numbers, run through the programming like it says in the owners manual and if it still doesn't work then you either have an issue or don't have that feature...
The backwards power seats and fob recongnition is a common/known issue. I just had mine fixed under warranty a few weeks ago.
Old Mar 18, 2008 | 04:33 PM
Yeah... That was very annoying...
I had mine done under warranty in August/September/October/whenever I got my leaky axles fixed... and my CEI problems I had for a few weeks...
Old Mar 18, 2008 | 07:55 PM
finall's Avatar
LisaM & Muddydawg75: What year are your vehicles?
Are they 2006 or 07? Or earlier years?
I would like to determine when the change occurred if there was indeed a change in the setup. Thanks.
Old Mar 18, 2008 | 10:58 PM
LisaM's Avatar
Mine is an 03.
Lisa
Old Mar 19, 2008 | 05:29 PM
Mine is an 03.... the best year for H2's BTW....
Old Mar 20, 2008 | 11:19 PM
HummerH2's Avatar
Mine is an 06 LUX and it does not work with the key fobs... doors only!
Old Mar 21, 2008 | 12:09 AM
finall's Avatar
Thanks to all for the replies.
Ok, That pretty much confirms it.
The earlier years had the movable seats via keyfob, the later years do not.
I would have thought that they would give you more in latter years, not less features.
