H2 hard steering won't stop
Old Apr 22, 2008 | 09:39 PM
jandrews's Avatar
Default H2 hard steering won't stop
I have a 2003 H2 that the power steering went out and even though i replaced it the power steering pump it is hard and brakes make you wonder if your going to stop. Power steering pump was purchased at my local parts store. I was told the pump is the smae as Chec and GMC suv's. Seems noisy as well so I think its the pump again.
Old Apr 22, 2008 | 09:59 PM
dwaxman1's Avatar
Default RE: H2 hard steering won't stop
Who did the install? If it was the dealer maybe you could take it back to them....
Old Apr 28, 2008 | 11:15 PM
warriorking's Avatar
The power steering pump is heavy duty for 2500 series trucks,because you also have hydro-boost,I don't know about aftermarket,but the pump from HUMMER has been redesigned with a new flow valve.it's possible that your aftermarket pump required you to install the flow valve from the old pump,witch in turn wouldn't help you too much
Old Apr 29, 2008 | 04:23 PM
Muddydawg75's Avatar
I had that issue... the dealership said it was within limits... and jacked the pressure in my front tires 5psi thinking I would be too stupid to notice...
I changed the fluid and made sure it was full.... my issue went away...
Old May 18, 2008 | 01:09 AM
Circuitguy's Avatar
We had the same problems with our 2003 and 2005 H2's. The problem is the power steering pump, when this goes out so does your power brakes. Both Hummer's had the pumps changed twice at the dealer under warranty. All is ok for a while but over time it goes out again. I dont think the pump can take powering the steering on a truck that is this heavy. Just my two cents...
SafariHummerH2
Jun 9, 2016 12:12 PM
Jack America
Jan 23, 2013 08:18 AM
jfoulker
Apr 10, 2011 10:12 PM
Dennis
Dec 6, 2006 09:35 PM
dilo2001gt
16
Jul 31, 2006 07:16 PM
