H2 cargo hook install
Old Mar 10, 2008 | 09:09 PM
bmbenear's Avatar
Default H2 cargo hook install
I'm trying to install some cargo hooks in the same rails that hold the luggage cross bars but can't figure out how to get the slide base down in the track. DoI need to remove a roof clearance light to gain access to the inside of the track? Thanks
Old Mar 11, 2008 | 09:05 AM
shortbus's Avatar
Default RE: H2 cargo hook install
to get access to the rail sliders you need to remove the plastic stop at the back of the rail, between the steel rail and the rear marker light. pops out without tools. sometimes the tabs break, so don't go gorilla on it trying to get it out. once that's out you can slide one of your crossbars out and put the cargo hooks between the bars if you want.
Old Mar 11, 2008 | 09:37 AM
bmbenear's Avatar
I should have mentioned I have a SUT. The rails run from front clearance light to rear clearance light. There are no stops, the rails butt right up against light housing.
Old Mar 11, 2008 | 09:59 AM
shortbus's Avatar
in that case i have no idea. nothing in the shop manual on the SUT. did you look in your owner's manual?
mgurgone
Aug 6, 2012 11:42 AM
ragz12
Mar 17, 2007 12:04 AM
dilo2001gt
Jan 30, 2007 07:11 AM
07HummerH3
Dec 3, 2006 04:09 PM
hmhpilot
17
Feb 21, 2006 03:15 AM
