H13 Silverstars
Thanks for the info GMan, I put a set on about 3 weeks ago. I paid 30$ for mine on a 25% discount at Advanced Auto. Fer sure the best 30$ Ive spent on my H3. I CAN SEE NOW
. Cant go wrong on these !
[IMG]local://upfiles/267/CCCF17F908064A8A9CC58167C8BD72B9.jpg[/IMG]
. Cant go wrong on these ![IMG]local://upfiles/267/CCCF17F908064A8A9CC58167C8BD72B9.jpg[/IMG]
Don't forget the rebate is on until Jan 07
I couldn't find the rebate on Sylvania's site, but it was here http://www.autobarn.net/silverstar.html.
Any threads on how to swap the bulbs out?? Also, Any threads on how to switch the lens on the side marker lights on the front fenders out?? I am getting smoked lenses but can not figure how to pop the stock ones out...
everything you see for an 06 will fit an 07 with no modification...same exact truck!!
Refiguy, bulb replacement is easy, just unplug the factory clip (wire harness plug thingy) from the back of the stock bulb, then feel for where the bulb touches the light housing itself...grab the plastic base of the bulb and turn clockwise I believe. won't take much pressure and it's only 1/4 turn or so to unlock the tabs. If it don't go in this direction go the other way cause it's been awhile and my memory blows
Reverse procedure to install new lights....BE VERY careful when plugging in the new light, sometimes aftermarket bulbs don't have the holes for the tabs in the factory plug in exactly the right spot, forcing it or pushing to hard can F**** everything up.
Can't help ya with the marker lights, I'll take a look tomorrow and let ya know if noone helps you before then.
Reverse procedure to install new lights....BE VERY careful when plugging in the new light, sometimes aftermarket bulbs don't have the holes for the tabs in the factory plug in exactly the right spot, forcing it or pushing to hard can F**** everything up.Can't help ya with the marker lights, I'll take a look tomorrow and let ya know if noone helps you before then.
ORIGINAL: G Man
The H13 SilverStar bulbs ($19 each) are now out and available for our H3's. I put a set in this past week, and they make a noticeable difference.
ORIGINAL: SedonaBoundH3
I've been planning to get them. Some aftermarket lights are pretty obnoxious; are other drivers flashing their brights at you?
ORIGINAL: G Man
