H1 transfer case questions
Old Aug 12, 2014 | 12:31 PM
Mdace's Avatar
Default H1 transfer case questions
Hey guys, I'm looking into a 96' H1, the one I found and like, the owner has told me that it is stuck in High lock, I haven't really been able to find anything online breaking down what causes this or how to fix it....Anyone have any clues?
Thanks A lot!
-Matt
Old Aug 13, 2014 | 10:27 AM
Stuck in High Lock or will only move in High Lock? If stuck in High Lock it could be as simple as linkage issues or as complicated as needing a T case rebuild.
Old Aug 14, 2014 | 12:30 PM
Mdace's Avatar
It will move and drive in high lock, but it's also stuck in high lock, and not able to shift out. Is this something worth perusing, or should I consider other options? I've tried to look up pricing for transfer cases' just in case it needs to be replaced, but I'm seeing a bunch of different prices, anywhere between $150.00 to upwards of $4000.00
Old Sep 21, 2014 | 11:02 AM
Rojolo's Avatar
I have a rebuilt transmission with a transfer case that was working just fine before taking it out of my 93 H1 that you can have for the price of a pizza!
I now have a Cummins 6bt with 47rh tranny and np241dhd transfer case
Cheers
Old Sep 21, 2014 | 04:22 PM
The 93 would have the TH 400 tranny and he would need the 4L80 or 4L80E. Rojolo where are you located?
Old Sep 22, 2014 | 07:40 AM
Rojolo's Avatar
Eastern Minnesota -
Since I didn't do the cummins conversion, I will check to see if they kept the original tranny - I'm quite sure they did.
cheers
Old Sep 22, 2014 | 08:53 AM
Has to be somebody that could use the 3 speed tranny.
Old Oct 25, 2014 | 11:26 AM
Mycoolsteel's Avatar
Did you ever find the solution to the transfer case? Mine is doing the same thing after an engine rebuild.
Old Oct 27, 2014 | 12:54 PM
Did you ever solve the stuck in 4 high problem?
ride450
Jun 26, 2021 02:00 PM
hudson4269
Mar 7, 2017 09:12 AM
flyinghunter
16
Apr 30, 2014 11:55 AM
mh307
Oct 16, 2007 05:24 PM
Jul 19, 2006 03:05 PM
