H1 bought and key listo PROBLEMS!!
Old Nov 15, 2016 | 02:40 PM
Alesline's Avatar
Default H1 bought and key listo PROBLEMS!!
I've just bought a H1 and I just got a key that has been lost.
I live in Spain where there's no Hummer official dealer.
I've been able to get a plain key and I'm trying to get a duplicate by using the door lock.
Does anybody know if that will work or it is necessary some kind of code for the key?
The car is a Hummer 6.5 turbo Diesel pick up built in 1997.
Please I need help!!! The car has been stopped for one month!
Old Nov 15, 2016 | 06:16 PM
HUMTECH's Avatar
The door lock cylinders on most vehicles only use the first 3 cuts on the key so using that as a base will likely give you an incomplete key cut. You should find a locksmith that can cut one to the ign cylinder or recode the cylinders to a new key cut.
Old Nov 15, 2016 | 06:20 PM
HUMTECH's Avatar
You may want to try contacting AM General and see if they can provide a key code by the vin number
Old Nov 15, 2016 | 06:49 PM
Alesline's Avatar
I don t understand What I have to do.
I thingh i need another key and i don t know, where can I find this kind of key.
I think, I have a big problem.
Do you think if i contact AM General and I give them the VIN number, they can get it for me???
Old Nov 15, 2016 | 07:04 PM
Alesline's Avatar
Are you sure that the key of a Hummer H1 1997 have a code??
My locksmith says that it dosnt have it.......
Old Nov 15, 2016 | 07:09 PM
Alesline's Avatar
This is the vin number of my car:
137ZA8337VE175500
Please, help!!!!!!!!!!!
Old Nov 16, 2016 | 06:36 PM
Paranormal's Avatar
Try contacting Dave @ Hummer Parts Guy. He has a new cylinder with keys for $30.
Hummer Parts Guy | HUMMER H1 5746883
Old Nov 16, 2016 | 07:05 PM
Ian Ward's Avatar
New cylinders only work once you have the old one out and you need the key to remove the cylinder. You can break out the lock cylinder but about 3 out of 10 times you will break the steering column. I would break out the old one and hope you get luckey. Try hamering a screw driver or a chisel in the key hole and turn it to the correct position ( its either run or accesory - i cant remember.) To remove the cylinder. It is a ford steering column - btw.
Old Nov 17, 2016 | 01:53 PM
Alesline's Avatar
Originally Posted by paranormal
try contacting dave @ hummer parts guy. He has a new cylinder with keys for $30.
hummer parts guy | hummer h1 5746883
:d:d:d:d:d:d:d:d
perfect!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 29, 2016 | 12:33 PM
BigDogOffroad's Avatar
This is not a thing. I asked a friend there years ago for a copy of all the keys and he said they actually didn't have the codes and they were never recorded by vin.
If you don't have a key you can replace the ignition and door locks which come with keys. Removing the ignition in one piece without the key present isn't going to happen (you use a chisel and a hammer).
Amanda Reusch
Aug 30, 2016 09:24 PM
samijane
Apr 18, 2014 07:58 AM
rtwash
Dec 13, 2013 10:45 PM
Fireman06
17
Jul 2, 2012 07:26 AM
PBR ME
Feb 22, 2009 04:42 PM
