H1 bought and key listo PROBLEMS!!
I've just bought a H1 and I just got a key that has been lost.
I live in Spain where there's no Hummer official dealer. I've been able to get a plain key and I'm trying to get a duplicate by using the door lock. Does anybody know if that will work or it is necessary some kind of code for the key? The car is a Hummer 6.5 turbo Diesel pick up built in 1997. Please I need help!!! The car has been stopped for one month! |
The door lock cylinders on most vehicles only use the first 3 cuts on the key so using that as a base will likely give you an incomplete key cut. You should find a locksmith that can cut one to the ign cylinder or recode the cylinders to a new key cut.
You may want to try contacting AM General and see if they can provide a key code by the vin number
Originally Posted by HUMTECH
(Post 340239)
I thingh i need another key and i don t know, where can I find this kind of key. I think, I have a big problem. Do you think if i contact AM General and I give them the VIN number, they can get it for me??? |
(Post 340240)
My locksmith says that it dosnt have it....... |
Originally Posted by Alesline
(Post 340242)
Are you sure that the key of a Hummer H1 1997 have a code??
My locksmith says that it dosnt have it....... 137ZA8337VE175500 Please, help!!!!!!!!!!! |
Try contacting Dave @ Hummer Parts Guy. He has a new cylinder with keys for $30.
Hummer Parts Guy | HUMMER H1 5746883 |
New cylinders only work once you have the old one out and you need the key to remove the cylinder. You can break out the lock cylinder but about 3 out of 10 times you will break the steering column. I would break out the old one and hope you get luckey. Try hamering a screw driver or a chisel in the key hole and turn it to the correct position ( its either run or accesory - i cant remember.) To remove the cylinder. It is a ford steering column - btw.
Originally Posted by paranormal
(Post 340275)
try contacting dave @ hummer parts guy. He has a new cylinder with keys for $30.
hummer parts guy | hummer h1 5746883 perfect!!!!!!!!!!!!!!!!!!!!!!!! |
(Post 340240)
If you don't have a key you can replace the ignition and door locks which come with keys. Removing the ignition in one piece without the key present isn't going to happen (you use a chisel and a hammer). |
