Ground Loop in H3
Old Oct 12, 2008 | 05:09 AM
ozHummer's Avatar
Default Ground Loop in H3
I have just completed an install of a new double din DVD head unit - JVCAVX810 - I decided to keep the Monsoon Amp and Sub. I have used the correct PAC interface to maintain the chimes etc.
It all worked - up until I turned the engine on! – then quite disturbing ground loop (interference by way of buzzing with the revs of the motor generally caused by different ground points being used – simplified)..
The only way I could nearly eliminate it was to remove the outer ground wire of the radio aerial and use just the centre antenna wire – a bit dodgy !!!!
Everything is isolated but the noise is still there ?-
An unrelated modification to the car also has shown up a very odd thing … I installed a roof mounted light bar using the bolt point used to secure the front of the plastic gutter moulding. Through a multimeter this was confirmed as a ground point, however the spot lights would not work! – they would only work when an independent ground lead was used from the light bar into the engine bay – very odd ?
So it is with this that I am wondering if there is something amiss with my grounding in the vehicle ? – has anyone experienced this or know why it is so ???????
Help would be appreciated greatly ?
Cheers
Old Oct 16, 2008 | 09:01 AM
Djox's Avatar
Default RE: Ground Loop in H3
Hi I have similar prob!! kind of ...I instaled double din DVD head unit - pioneer AVH p4000dvd..But because i was out of Country i told my brother to do that at some rendom shop around here ..and they intaled it but when i got back i saw that every time i turn on the car and as soon as the HU starts there is very lound "boooom" noise coming out of my speakers and also when i turn it off .... I went to that shop and they told me that they dont have idea because this is stuff is from US [:@] ..and i am in Serbia right now. Any one knows whats wrong what could it be?
[align=left] [/align]
Old Oct 17, 2008 | 06:37 AM
ozHummer's Avatar
Djox - The thump is because they have connected the low level RCA output up to the input of the PAC box.. Take it back and tell them to read the installation guide!! - It must use the high level speaker line out from the new head unit into the cambus module... Your thump will go away and it will be fine ...!! Remind them that you have the Monsoon AMP !
Old Oct 17, 2008 | 12:21 PM
Djox's Avatar
tnx oZ... i will do that as soon as i go back there coz i am not there till dec 19[:@] miss my ride but its gona be nice when i get there its gona be snowing[8D]..I have 1 more question can speakers get damaged like this coz my brother is driving car!? he told me some times he doesnt hear that happening!
Old Oct 20, 2008 | 03:45 AM
ozHummer's Avatar
If the otput power of the thump exceeds the power capability of the speakers then yes - Thumps are never a good thing in speakers as they can over extend the voice coil and that can rip or destroy speakers.Best to have it fixed asap...
Old Nov 16, 2008 | 12:35 PM
955i's Avatar
OzHummer did you ever get this sorted out?
I am having similar issues with my install, Kenwood DDX-7019, PAC interface, and retained Monsoon. Is your noise always there? Mine was noise free for a couple of days before it started and now comes and goes (more comes than goes lately). Also, the noise seems to only come from the drivers side rear speaker but doesn't sound like speaker damage, more like ground noise, crackling and whine that changes with RPM.
Cryonics
Mar 3, 2013 10:03 PM
theBroken
Jul 14, 2011 03:45 PM
HummerGuy
17
Dec 30, 2007 09:22 AM
Tinseast
Jun 3, 2007 06:59 PM
importkiller
36
Apr 1, 2007 02:20 PM
