Got the H3t Back
Old Oct 5, 2018 | 08:32 PM
FloridaH3t's Avatar
Talking Got the H3t Back
Well a bunch of work has been done but the ''Service Traction Control'' still showing but driving it with the traction off it is running great but I did notice with the light switch set at Auto the headlights are not coming on. Could this be a clue? They do work when switched to on. Anyway gonna drive the crap out of it this weekend and see where it takes me!
Old Oct 5, 2018 | 08:39 PM
FloridaH3t's Avatar
If I do not turn the traction control off there is a shudder in the LF when letting up on the gas approaching a light ect.
Old Oct 7, 2018 | 07:52 AM
FloridaH3t's Avatar
OK Truck is running pretty good Stability Fail Service Traction STILL ON
Codes showing:
P013E
P0300
P0856
P2432
They have all been cleared and keep coming back, any ideals? Please
Old Oct 9, 2018 | 05:38 AM
FloridaH3t's Avatar
anyone have any thoughts about the above codes
Old Oct 10, 2018 | 08:16 PM
norinco3264's Avatar
P0300 is random misfire. The others I can try to look up tomorrow.
clean throttle body. Clean mass airflow sensor. Replace spark plugs with AC Delco oem. Replace air filter. Make sure air resonator box hose isn't dry rotten.
Old Oct 10, 2018 | 09:47 PM
FloridaH3t's Avatar
Thank you for your reply Air flow sensor was cleaned then replaced The truck is not misfiring even though the code shows. If fact the truck is not doing anything the 4 codes show it doing. Another member suggested it might be a bad instrument cluster. Your thoughts?
Old Oct 10, 2018 | 10:06 PM
Hoff's Avatar
Was your fuse block messed with? If so, maybe check that it is back in correctly? Battery terminals have been changed? Just throwing it out there, wish I could be more help.
Old Oct 13, 2018 | 04:40 AM
FloridaH3t's Avatar
GEEZ another problem......... I have been driving the truck and it has been doing good with check engine light on and service Traction Control warning. I turn off the Traction Control while driving with the button. Last night while accelerating to get on highway not much power and the the REDUCED POWER indicator shows and check engine light starts flashing. I was able to limp home doing 45 mph, Now what should I be looking for? Using the search feature I see clean throttle body, PCM, replace spark plugs & air box. Does it ever stop with these trucks?
Old Oct 13, 2018 | 07:25 AM
DJB's Avatar
DJB
If the CEL was flashing, there should be a misfire code in memory (P0301 would indicate misfire on cylinder number 1, for example). Clear the code, swap the coil from whichever cylinder was misfiring to another cylinder. Go for another drive and see if the misfire moves to the cylinder where you mounted the suspect coil. If the misfire moves with the coil, replace that coil. If not, post back and we can go from there. Which engine do you have?
Old Oct 13, 2018 | 08:39 AM
FloridaH3t's Avatar
Thank you DJB when I went to start truck today after posting the above it would not start completely dead and security lock indicator showed on dash finally got it to start how I do not know had it scanned and only codes showing were P0856 Traction Control Torque Request & P2432 Air Induction low voltage I did notice the positive factory battery terminal was loose also. Truck is semi driving normal now after a few mile test dirive. Thanks for the help & info
jd1368
Feb 18, 2019 04:43 PM
Gdraft
Jan 5, 2017 10:41 AM
Det2008SUT
Apr 29, 2013 09:19 AM
H3 Brad
Apr 8, 2013 04:46 PM
fhydro
Dec 6, 2010 01:12 PM
