Gear shift console removal...
Old Feb 5, 2008 | 02:10 PM
Bronx's Avatar
Default Gear shift console removal...
Hey all! I'm baaaaack!
I don't know if any of you have noticed this, but the plastic insert that slides with my gear shift to keep the inside workings covered, has ripped and is making shifting harder as I have to keep constantly pulling it back up...if this makes any sense. Anyone know where I can grab instructions on how to take apart my gear shift console so I can attempt to fix this crap myself?
Everytime I turn around I'm fixing something else...new sunroof and headliner going in on thursday now...but she'll be sooo pretty after I do!
Old Feb 6, 2008 | 02:12 AM
Default RE: Gear shift console removal...
That happened to mine also, I had my dealer replace it for me....No Charge!!!!
I'm PRETTY SURE you have to take off all the bolts INSIDE the center console, they're hex if I remember properly!!
Here, I found this in a Search:
"Open the center console storage area compartment door. Take out the four screws that hold the black plastic storage bin in place. Pull the storage bin straight up and out, it will just slide past the compartment door hinge. Take out the four screws that hold the center console storage area compartment door hinge to the center console. This step is not absolutely necessary but may make dealing with the center console a little easier.
Three screws hold the center console end cap in place. One screw is on top and the other two screws are inside the compartment that is just under the rear seat radio controls. The end cap will pull away and you can disconnect the five wiring harness plugs. Be careful what the plugs that go to the rear seat heater control, a very small screwdriver can be used to lift the retainer while you pull out the plug.
The shift lever has an allen screw that needs to be loosened to remove the ****. Note that the allen screw is not set very tightly. To remove the cupholder tray you must grasp it firmly and pull it straight up. I used a screwdriver along the edge at the place where the three mounting tabs hold the cupholder tray in place. Be sure to put down thick tape or a rag to keep the screwdriver from scratching the console. As you can see in my picture the three red arrows show the locations of the cupholder tray mounting tabs. The other two pictures show what the bottom of the cupholder tray looks like and what the clips look like. My pinkie is just touching the tab on the bottom of the cupholder tray that slides into the slots wear the red arrows are. The metal clips are to be pushed onto those three tabs before the cupholder tray is put back in place. If you look closely at the metal tabs you will see that they each have four sets of opposing fingers. The outer to sets have sharp barbs that dig into the plastic tabs. If they are not taking a very good bite you can use a small pair of needle nose pliers and beed the barbs inward a little so they take it better bite into the plastic. Or you can just stop by the dealer and pick up new clips before you start this project. Please note in the picture where my pinkie is just touching the plastic tab, on the left side of the picture, there is a another plastic tab and metal clip shown. This you do not need to take apart. This holds the chromed trim piece to the cupholder tray. Anyway, it is gives a good idea what these clips look like and how they work. When I pulled my cupholder tray out from the console most of the clips fell down inside the console and did not stay on the plastic tabs.
To loosen the center console you now have to remove the bolts shown by the white arrows. If your goal is to get to the radio head unit in the dash then you do not really have to take the center console out. You can just slide it backward towards the rear of the truck about an inch. Now when you take the really long allen head bolts out of the center dash trim piece it can be taken completely off."
Old Feb 6, 2008 | 09:25 AM
Bronx's Avatar
Thanks HB...that was awesome..yeah, I went to the dealer...they told me I had to replace the entire console piece that contained the TINY rubber piece to the tune of $500!!! So now I'm wondering what other options I have which is why I wanted to remove it on my own...I'll see if I can give this a try and repair it the best I can...Thanks brother!
Old Feb 6, 2008 | 02:37 PM
NoProbs!!!
Old Dec 15, 2008 | 01:53 PM
RDODoc's Avatar
Hi Humm....
Just picked up a Used 06 H2 in great condition - with one exception: The gear shift lever has a slight amount of play in it if you twist it. I understand theres an allen screw (or two) somewhere to tighten it.
Any ideas where the screws are and how to gain access to them?
A search of all the forums leads me to believe Im the only one with this issue.
Any help is appreciated.
Old Dec 17, 2008 | 11:44 PM
katherine's Avatar
What material did you use for an inner fender?
_______________________________________
buy hid
Old Dec 18, 2008 | 08:49 PM
dej1001's Avatar
The Allen key is on the front of the gear shifter facing the radio. There is just one screw and you need a metric set I believe. Just put the truck in low gear and you should be able to see the screw.
Girl_Wonder
Nov 30, 2020 10:55 AM
mrjohnp
16
Oct 6, 2016 05:00 PM
Johnny B. Epic
Mar 7, 2012 07:53 PM
chazyrae94
Jan 6, 2012 02:47 PM
2006 H2
Mar 16, 2009 11:33 AM
