Gasoline Octane???
Old Mar 15, 2006 | 05:41 PM
RutDogg's Avatar
Default Gasoline Octane???
I have read on a couple of different Hummer forums that you should only use gasoline rated at 87 octane. After reading my owner's manual it states to use 87 or HIGHER octane. Is there a reason why you wouldn't want to use a higher octane? The owner's maunual does not state to use ONLY 87 octane, so why shouldn't I use a higher octane?
Old Mar 15, 2006 | 06:04 PM
shortbus's Avatar
Default RE: Gasoline Octane???
no real reason that you shouldn't, unless you like throwing away $.20 per gallon. it's your money, but you'll get no real benefit from it.
Old Mar 15, 2006 | 07:15 PM
Dennis's Avatar
ORIGINAL: RutDogg
To expand on Shorty's explaination just a tad more..
The Engines are designed (compression ratio) and the PCM (engine computer) are programmed to adjust the spark firing angle for a certain range of fuel octane. The engine has what is called a predetonation sensor to signal the computer to advance the timing or retard the timing to correct for preignition (known as knocking or pinging)..But it has a limited range from retard to advance. So the fuel has to be of the correct octane for the timing to fall within this range. If you use a slower burning HIGH octane fuel, the spark control must adjust itself to it's full Advanced end of the spectrum...But it will not go far enough to compensate for the High octane fuel (usual above 90 or more)..What ends up happening is that, since the fuel burns slower and incompletely, a lot of left over unburned fuel remains and carbons up the combustion chambers. Resulting in higher compression eventually and then you are force to use the higher octane fuel by fault...So the faster burning 87 octane is optimum for proper combustion efficiency as these engines are set up for. Using any higher octane is a waste of money too...89 octane is a blend of the 87 and the 92+ at the pump's mixing valve.
Old Mar 15, 2006 | 07:41 PM
shortbus's Avatar
eloquently explained. i'm gonna save that explanation, it's just so darn insightful.
[sm=happy046.gif]
Old Mar 15, 2006 | 09:19 PM
Dennis's Avatar
Sorry for being so long winded..I'm an Instructor of engineering by trade..So sometimes I can't help myself and I just start spewing forth endless cocktail party type trivia.[sm=helpout.gif]
Old Mar 16, 2006 | 10:11 AM
dilo2001gt's Avatar
ORIGINAL: RutDogg
MY dealer told me only use 87 that's it. He told me the high you go it will hurt the motor why i'am not sure.
Old Mar 16, 2006 | 11:51 AM
Dennis's Avatar
ORIGINAL: dilo2001gt
ORIGINAL: RutDogg
Mark..reread my post above...If you use premium (92 octane or higher) you are pissing away money and carboning up your engine.[sm=wakeup.gif]
Old Mar 16, 2006 | 12:10 PM
dilo2001gt's Avatar
ORIGINAL: Dennis
ORIGINAL: RutDogg
Hey take it easy on me i been sick for over a week now likey i can use the key board never mine read[sm=smiley23.gif]
Old Mar 16, 2006 | 12:22 PM
Dennis's Avatar
ORIGINAL: Dennis
ORIGINAL: RutDogg
Sorry Pal..I was wondering where you've been...Hope you get to feeling better..So I can really have fun..[sm=wootwoot.gif]
Marauder
Jul 9, 2008 09:34 AM
Brodie
Mar 17, 2008 04:03 PM
Body Armor Guy
24
Oct 28, 2007 07:57 AM
beachman
Nov 20, 2006 04:26 PM
cyp10
Nov 3, 2006 05:50 PM
