Gasoline dripping
Old Nov 12, 2018 | 09:01 PM
Bronco40's Avatar
Default Gasoline dripping
Gasoline dripping while engine is running 2005H2
Old Nov 12, 2018 | 09:02 PM
Bronco40's Avatar
Seems like it’s coming from above the tank....midway under truck
Old Nov 13, 2018 | 01:32 PM
Right where the fuel lines run.
Old Nov 14, 2018 | 11:15 AM
mulepic's Avatar
It's tight up above the tank. Get a mirror and a light up there and you'll see two sensors up there. I had to put some sealant around where those sensors plugged into the tank. Otherwise I'd have a gas smell particularly when the tank was full. I just think the rubber gasket around those sensors dries out over time.
Old Nov 14, 2018 | 06:12 PM
LoJac963's Avatar
Also, if you decide to drop the tank for repairing those gaskets, think about replacing your trailing arm bushings as well. The front bolt is much easier to get out with the gas tank dropped.
Old Nov 15, 2018 | 07:23 AM
Also, dont plan on dropping the tank until you are near empty.... gas is heavy.
Old Nov 15, 2018 | 07:56 AM
calif phil's Avatar
In addition to the other great advice, if your rig has over 100k miles I would replace the fuel pump, while you are in there.
Old Nov 18, 2018 | 07:29 PM
Dragracer_Rob's Avatar
When it happened to me the metal fuel lines on the pump rusted through. Replaced the pump.
joshey
Apr 22, 2015 04:30 PM
ultraclassic01
Jan 4, 2012 06:50 PM
Mechaworx
Nov 29, 2011 06:30 PM
patricktheelder
Jun 19, 2010 11:50 PM
Greenblade
May 27, 2006 05:01 AM
