gasket replacement on power steering
Hi Guys,
Has anyone replace the gasket on the lid of their power stering box? mine is leaking and I tried to change it, removed 4 bolts ok and the nut on the threaded bolt in the center of the lid but I couldnt get it to come off to get the new gaset on so used some gasket paste in the mean time, helpappreciated |
RE: gasket replacement on power steering
I don't want to rain on your parade.... but the stud and jamb nut is an adjustment for the freeplay...
the 4 bolts are to take the center part out.... the part attached to your pitman arm... You are not attempting a simple gasket change... you are toying with having to rebuild your entire box... In my humble opinion.... or course... advice may vary here... http://img50.imageshack.us/img50/6540/sagboxyr7.jpg |
i've never taken mine apart, and it never leaked. but the sector shaft that connects to the pitman arm was worn and they replaced the whole box - luckily it was under warranty, 'cuz those babies ain't cheap and neither is the labor. if you put it back together, how is your steering now?
ORIGINAL: Muddydawg75 I don't want to rain on your parade.... but the stud and jamb nut is an adjustment for the freeplay... the 4 bolts are to take the center part out.... the part attached to your pitman arm... You are not attempting a simple gasket change... you are toying with having to rebuild your entire box... In my humble opinion.... or course... advice may vary here... http://img50.imageshack.us/img50/6540/sagboxyr7.jpg Thanks for the info Dawg, steering is ok and no leak now, I just thought it would have been better to fit the proper gasket. Problem is in Ireland no mechanic wants to look at its as not a standard run of the mill car, but then that why I bought it. Is the correct place for the pitman arm up tight to the bottom of the pump? |
