FYI: H2's OEM Brake Pads - AC Delco product ID's's
Old Sep 23, 2014 | 12:47 PM
Doberman_Fan's Avatar
Default FYI: H2's OEM Brake Pads - AC Delco product ID's's
In case you are interested in acquiring OEM brake pads for your H2, here are the AC Delco product ID's for the front and rear:
">          <img src= " /> ">
         ACDelco 17D785CH Professional Durastop Ceramic Front Disc Brake Pad Set     ACDelco 17D785CH Professional Durastop Ceramic Front Disc Brake Pad Set
Sold by: Amazon.com for $43
(this is the rear)
         ACDelco 17D784CH ACDelco 17D784CH
Professional Durastop Ceramic Front Disc Brake Pad Set     Professional Durastop Ceramic Front Disc Brake Pad Set
Sold by: Amazon.com for $45
(this is the front)
Disregard the product description whereby it says the 17D7885CH are for the front. They may be for some vehicles; but, not the H2. 17D7885CH are for the rear as it indicates should one go to AC Delco's site and click onto Vehicle type & then Part type.
Anyway, I just recently had these AC Delco's installed after having AutoZone's best quality H2 pads on my vehicle for 2 weeks. I thought my mechanic had put OEM's on; but, I learned otherwise soon after. The Auto Zone pads squeaked & the stopping power was not as good. Now, it is great again!
Old Sep 24, 2014 | 08:30 PM
mcioci's Avatar
(this is the rear)
ACDelco 17D784CH
(this is the front)
Good to know because hummer dealer priced brakes and rotors all the way around for $910.00 installed. Do you know the OEM part numbers for the rotors?
Old Sep 25, 2014 | 10:00 AM
The following are the OEM rotors from AC Delco for a 2003 - 2007 H2:
I seem to have misplaced my documentation where I ordered the rotors from; however, to get the proper OEM part #, just go to the AC Delco site listed below:
ACDelco Parts
I will tell you this though, I would order for my H2 next time the SP Performance rotors I put onto my 08 Jag XJ & my wife's 04 Jag XJ because my H2 already shows corrosion whereas both of the Jag's rotors' look as clean & shiny as when they came out of the box. Performance has been great too.
If interested in the SP Performance rotors for an H2, here is the link for them:
Front: SP Performance T55-056-P | eBay
Front part #: T55-056-P
Rear: SP Performance D55 057 P Diamond Slot Brake Rotors Zinc Plating L R PR Rear | eBay
Rear part #: D55-057-P
By the way, I also installed with the shocks what a lot of folks over look what are called Suspension Travel Bumpers. GM charges $33.52 each for the 2 in the front which is about $20 more than online; but, you will not incur approximately $10 for shipping & you will know it's the exact part. GM's part # is: 15835667
I will copy this info & put it into a thread under rotors; maybe it will help others out.
Doberman_Fan
Mar 4, 2015 02:22 PM
Doberman_Fan
Sep 25, 2014 10:15 AM
HummerH2T2
Sep 16, 2013 08:55 AM
crazytodig4u
Mar 12, 2007 09:49 PM
RickKirby
Nov 2, 2006 10:45 AM
