fuse box
Old Jun 21, 2008 | 07:58 PM
rromas00's Avatar
Default RE: fuse box
what is this part called.....drill a hole to run to the fusebox?
Old Jun 22, 2008 | 12:00 PM
DILLIGAF08H3's Avatar
I usually use the big rubber grommet for the vehicle harness. No drilling needed, just find it, poke through it with a straightened wire coat hanger, tape your wire to it and pull it through.
Old Jun 22, 2008 | 03:03 PM
RyanCodyH3's Avatar
ORIGINAL: DILLIGAF08H3
Exactly what I did
Old Jun 22, 2008 | 04:57 PM
motley1987's Avatar
I'm trying to do this with my radar detector. I got the "add a circuit" part like in the picture, but when stripping the power cord for my detector, there is a red wire and a white wire. Which one do I connect to the extra fuse spot that goes in the fuse box?
Old Jun 22, 2008 | 05:47 PM
importkiller's Avatar
90% of companies use the red wire or red striped wire as the hot or +12V lead. That red or red striped wire would be the one that goes to the add-a-circuit wire, the black or black/white wire would just go to a good ground.
To be safe look at the cigarette lighterplug you cut off the radar detector...there will be the same color wires in the plug as the ones you just described. See what color wire is soldered to the tab that the fuse makes contact with...that will be the hot or +12v wire
Old Jun 22, 2008 | 05:53 PM
I am assuming you cut off a cig lighter plug. Use a continuity checker to check which wire is connected to the end contact at the point.
Old Jun 23, 2008 | 01:05 AM
RyanCodyH3's Avatar
For the radar detector, pop the hood and put each wire on the battery terminals. If it doesn't work one way, switch the wires. Bingo.
Old Jun 23, 2008 | 02:13 AM
Steve #1's Avatar
ORIGINAL: RyanCodyH3
If it still dosn't work, that means you had it wrong the first time and you fried the radar detector and need to go buy a new one.
Verify which wire was connected to the center post on the plug it will need to connect to +.
Old Jun 23, 2008 | 05:24 PM
yes make sure you check first. there is no guarantee there is an protection for reverse polarity.
JBROEREN
26
Jan 12, 2017 11:21 PM
ImNoSaint
Feb 5, 2014 10:16 PM
JMaitem
Mar 22, 2013 07:12 AM
lowyalty1
May 18, 2012 10:08 PM
neverendingproject
Jul 8, 2009 10:37 PM
