Fuel door replacement
Old Dec 27, 2015 | 11:52 AM
650Hawk's Avatar
Default Fuel door replacement
I know, there have been several threads on the fuel doors (removal/installation), but since mine was different than all of those, I thought I'd post a new thread. My Alpha had a black aftermarket fuel door. It was a bit "busy", and the finish was not the best. I got a new chrome billet unit (aftermarket) for Xmas, so it was time to make the swap.
Now, every thread about the fuel door kept saying that they are held on with simple clips, and to just "pull hard" to remove. I didn't believe it with mine; I could actually see parts of threaded studs if I looked into the opening and between the fuel door frame and the fender; just "pulling hard" would've resulted in a broken fender. I figured that I would need to remove the fender in order to verify exactly how it was installed and remove it. But it's cold outside, and of course cold means brittle; I really didn't want to break any of the clips holding the fender on.
But after taking a closer look, I realized that I didn't need to remove the fender after all. Simply removing the inner fender liner (5 clips and 5 10mm bolts) exposed the entire inside of the fender. Success!
Here's what my original fuel door looked like:
Her's the inside of the fender after the removal of the liner. You can see 2 of the nuts/studs holding the fuel door on. They were bolted through the fender and the fuel cup:
Here's the backside of the removed fuel door. It is set up to use up to 5 studs, although only 4 were used:
And finally, here's the new unit installed:
New fuel door, no broken clips, no broken fender...Happy Camper!
Old Dec 28, 2015 | 07:37 AM
choochmalooch's Avatar
Cool
Excellent job. You did your homework.
Old Dec 28, 2015 | 09:41 AM
You mean every thread about the OEM Chrome fuel door?? Which yours was not.
Old Dec 28, 2015 | 09:52 AM
650Hawk's Avatar
Default correct
Point taken. However, one thing missing from every single one of those posts, even when asked, was the fact that removing the fender liner (very easy) exposes the backside of the fender. That makes it easy to see exactly how the door is attached, whether OEM or aftermarket.
Old Dec 28, 2015 | 09:56 AM
Good tip. Your new one looks way better than the old one you swapped out.
Old Dec 28, 2015 | 10:00 AM
650Hawk's Avatar
Default thanks
Thanks, I agree.
collega
21
Nov 20, 2015 09:00 AM
yardcrew
Aug 12, 2014 08:06 PM
mismatch
Private 'Wanted' Classifieds
Sep 1, 2013 10:42 AM
Davidh3
Nov 10, 2011 04:51 PM
*fill-up*
Sep 11, 2010 08:57 AM
