FS: Hummer H2 Billet Chrome Hood Latch Set + straps
Old Aug 10, 2021 | 12:19 PM
finall's Avatar
@MixManSC
Thank you so much MixMan for the explanation. And your confirmation!
Much appreciate it.
Yes, these are also used on the C5500 chassis.
I recently found that out. I had a load of soil delivered, and was surprised to see the same hood straps on that GM truck.
Old Aug 10, 2021 | 07:35 PM
Originally Posted by MixManSC
That IS a genuine GM part number and those are a genuine factory part. The factory part numbers are often not referenced - often a general replacement part number is used instead.The 8896 number in this example is the initial revision release number. If you order one of the later superseded GM part numbers directly from a GM dealership, they come with the same install document with the original revision 8896 part number on the document. A few years back, for an ambulance service we used to work with, I ordered the same ones for a C5500 chassis ambulance.
When do OEM parts come with instructions? That part number is NOT in the GM database!
Again the OEM part #'s:
Part Number: 12499435
Supersession(s): 12498995
Old Aug 10, 2021 | 08:40 PM
finall's Avatar
Here you go, accusing a long-time member in good standing to be a lier.
And posting members private info on this forum is the pinnacle of stupidity. And you have achieved that pretty quickly. Well done!
Old Aug 11, 2021 | 01:42 PM
Old Aug 11, 2021 | 02:46 PM
Sorry HUMMERZ, 100% incorrect in this case. This latch is for SE H2s.
Old Aug 11, 2021 | 03:20 PM
88962948 is OEM part number not 88962941.
Old Aug 11, 2021 | 03:35 PM
Old Aug 11, 2021 | 04:01 PM
Originally Posted by finall
Just because the part number is not in you eBay-sourced parts CD, means nothing.
It shows in every dealer’s database. You are a troll.
You sir, continue to demonstrate that you are a moron with every additional post. Accusing a long-time member in good standing to be a lier. It is YOU who is the lier. And everyone reading this can now see that.
Doubling down on your stupidity demonstrates that clearly. Interfering for the second time with something I am trying to sell makes you a 100% ***. Hiding behind the internet.
Hope others on this forum take note of your ignorance. You know nothing about the H2.
Posting members private info on this forum is the pinnacle of stupidity. And you have achieved that pretty quickly.
[04-24-2021, 12:59 PM]Here is the link to the chrome hood straps:
https://www.ebay.com/itm/333487984529
Had them shipped to Canada. Not cheap, but nice to have. Mine were completely corroded.
Seems that anything bilet aluminum that is chrome has corroded in a few years. Corrosion starts where steel meets aluminum, and in this case at the stainless steel pins that hold the rubber strap. Ditto for my locking gas cap from DefenderWorx. I am on my third one, and it is ready to fall off. I am on my third set of chrome-peeling OEM wheels (they last about 3 years)
I think someone else had OEM chrome hood handles on ebay also, but I already have a 2nd set.
The steel and plastic chrome parts on the H2 are still all original, and this limited edition has tons of it.
"lier"!
Old Aug 11, 2021 | 04:06 PM
finall's Avatar
Hello Tainter,
Want to express my sincere Thanks for finding that confirmation!
Although the part number 88962948 is not the same as my 88962941, what this does show is that there are other part numbers for this part, for which Hummerz wrongly stated that there are not.
So far I have found 6 different GM parts number for these chrome hood latches.
I can only speculate at this point why there is both a 88962948 and 88962941 part number.
All I can tell you that I was told this is a genuine GM part. So it it?
May have been early production (that is why that part number can not be found, and it shows long-gone www.hummer.com on the install sheet header)? Or it is a typo on the spec sheet, or ?
Anyways, I will make some calls and see what the truth is.
Much appreciate your help with this.
You and MixManSC are fine examples of what this Hummer forum SHOULD be all about. Helping other fellow Hummer owners.
Old Aug 11, 2021 | 05:22 PM
finall's Avatar
For a decade or longer.
It is not uncommon for GM accessory parts to get shipped with installation sheets. Even all my OEM wheels did. Every single one, bought during various years.
