FS: 2004 H2 Hummer, Yellow, 124k miles, $16,000
Old Sep 3, 2015 | 12:50 PM
accely's Avatar
Default FS: 2004 H2 Hummer, Yellow, 124k miles, $16,000
2004 H2 Hummer - TONS of upgrades - Well maintained+CARFAX
**CARFAX AVAILABLE!** I can send you the Carfax report showing this H2 has had no problems in the past and has had routine maintenance.
This is one amazing H2 with ALOT of upgrades and maintenance. This H2 is in mechanically great condition and interior/exterior is good condition. Tires and rims are brand new.
Book value is about 19k. Priced to move at $16,000 FIRM. My loss is your gain with everything that has been done to this H2.
Highlights:
124k Miles, excellent mechanical shape
Runs amazing, almost all major components have been upgraded/replaced, see list
All maintenance done as suggested and oil changes performed routinely
Over $10,000 in upgrades and fixes
Suspension upgrades support 37" tires and higher
Interior and exterior are in good shape.
Done @ 100,000 Miles:
Canister vent solenoid replaced
Brake fluid flush
Trans fluid flush
Front Differential fluid flush
Rear differential fluid flush
Transfer Case service w/ fluid flush
Fuel system cleaner w/ flush
Cooling system flush
Power steering flush
Spark plugs & ignition wires replaced
Idler Arm OEM
Both front axle seals replaced
Done @ 117,000 miles, Summer 2013
Cognito UCA kit
Bilstein 5100 shocks
Kryptonite HD Sway Bar End Links
Traxda Lift and Level Kit (Avg lift 2.0-3.0"Front & 1.25"Rear)
Moog Tie Rod Out-ES3609
Moog Tie Rod In-ES3488
NAPA pitman arm
Powerstop brakes and rotors (front)
AFE Cold Air Intake - Magnum Force Stage 2
Replacement stock exhaust (40k miles on the new one, replaced the original 117k mileage exhaust)
Superchips Cortex Performance Tuner 2950
Done @ 121,500, Fall 2014
Powerstop brakes and rotors (rear)
35" Nitto Terra Grappler A/T tires (like new, only 3k miles on them)
17" Rockstar XD Rims (brand new model)
Done @ 122,500, Jan 2015
New AutoZone Gold Standard battery w/ 3 yr warranty
48 point inspection done at Hummer dealership (noted airbag sensors) everything else is good to go
Misc:
Viper remote start system, LED key fob, 2-way up to 1 mile.
New OEM H2 floormats
Installed Black texture door handles
Black H2 logos
Line-x'd Brush guard, tail lights, fenders, bumpers, grill, skidplate
Replaced dash modules (4x4,dome lighting, rear wiper)
Rockford Fosgate door speakers
Clarion CC510 Reverse camera w/ frame mount
Clarion NX501 Navigation system with remote
JBL 10" Subwoofer and JLAudio AMP under rear seat w/ custom box.
50" 300W 30000 Lumen LED lightbar on roof
2x 4" LED Work lights behind the lower grill
Replaced rear dome light housing
White LED interior light upgrade
HID headlights with new housings
LED front turn signals
LED rear taillights
LED bulbs for existing fog light housings
Known issues:
2x Front air bag sensors needed replaced (est. $250)
Minor plastic cracked on rear roof tail light area.
accely
Jun 13, 2015 12:58 PM
bullitt5244
16
Oct 21, 2010 01:53 PM
showtimecars1
Sep 5, 2007 04:21 PM
RickLF
Aug 23, 2007 09:19 PM
IgottaH3
31
Apr 14, 2007 09:49 AM
