Sounds more like an amatuer mechanic.
Yay an oil warning light came on today when I got to work
I replaced the spark plugs , serpentine belt, and cleaned the throttle body on Sunday and the dam thing is still stalling because the dam rpms will jump around between 1200 and 500 when stopping and then dive down and stall. It's really random when it happens. If anyone has any suggestions please share because the dealership has basically given up.
Wife had a Chevrolet Cavalier that more or less seems to have done the same thing. Would run fine for a while several days in a row. Then you could stop at a stop light. Car could have been running fine. Then it would start to run ragged with RPM jumping around and no power, when you got ready to go, it would lurch a little, then die/stall. Car may or may not start back up. If it started, often it would run fine for a while, then repeat process. Problem always seemed to reappear when starting from a stop, often at a stop light. Mechanic diagnosed problem as a faulty Throttly Position Sensor. Replaced TPS and car ran great with no problems.
Meant Throttle Position Sensor vs Throttly Position Sensor in previous post.
Originally Posted by woody.167
(Post 248139)
air,gas ,spark,timing needed to run
fuel injectors,fuel filt,fuel pressure gm mechanic otta know something huh. no codes? |
Originally Posted by thermalfrost
(Post 248140)
its your TPS sensor, I had this problem on my yes Honda Accord 2001 v6 coupe commuting car a few years back. It was still under warranty and Honda replaced the whole throttle body/ sensors and all and it was good to go ! Good luck and hope this helps..
TPS sensor or possible mass air flow sensor.
