Frustrated
My 2008 Hummer H3 is making a sound when I take my foot off the gas and coast. It's very rhythmic like a wheel bearing but it's not. I've replaced all my tires because I was told it's tire noise. I replaced a bearing at the end of the drive shaft and that didn't do it either. Can someone help?
Could be pinion bearing
I'd recommend to take it to a shop that can place it on rack and run it through it's paces.
I've done this a couple times when I could not find a very troubling issue. |
Warped rotor or hub bearing?
Not saying that this is the cause but have you made sure the slide pins and hardware for brakes are clean and fully working? They get really rusty.
More information...
Originally Posted by BruceS
(Post 345488)
I rebuilt my whole front axle with bearings (there are 8 sets), thrust washers, seals and fluid for about $225-250. No telling what a shop would charge.
I bought most stuff through rock auto but if you trust certain sellers on eBay you can find parts cheaper. It's not hard to pull axle and get apart. |
