Front wheel camber worn bearings? 1990 H2
Old Apr 21, 2014 | 03:11 AM
Otis Arms's Avatar
Default Front wheel camber worn bearings? 1990 H2
Not sure exact problem so am posting pics if any1 can make quick id on this issue
Old Apr 21, 2014 | 08:00 AM
tharber's Avatar
Not sure what you are trying ot show.
The easiest way to see if your front 'hubs' or bearings are shot is to jack up each side, grab top and bottom and see if there is any movement. If so, chances are that at least your hubs are bad. Typically this will also lead to inner tire wear.
Tim
Old Apr 21, 2014 | 12:46 PM
Dieseldrums's Avatar
1990 h2??
Looks like the tires are rubbing, are they larger than the stock 35?
Old Apr 22, 2014 | 03:15 PM
H2CANEPADESIGN's Avatar
Hard to diagnose from a pic. all I can tell you for sure is that your alignment is out. could be bearings, bushings, ball joints, tie rods, idler arm, pitman arm, bent frame and so on and so forth. need more info to help you.
cantex11
Aug 24, 2015 10:53 AM
oceanbrave
Jun 16, 2015 03:23 AM
Jgalvar
24
Apr 21, 2014 03:18 AM
Chernandez9
Sep 11, 2013 11:16 AM
gsmith9898
Aug 27, 2013 02:00 PM
