RE: Front Leveling/Shocks & 35" Tire/Wheel FAQ
Perfect !! I'm bouncin through here tryin to get all the info I can on tires, leveling, etc and this post shows up........perfect.
Thanks Now......gotta find some dirt on a roof rack with hooks.......no bars wanted. [IMG]local://upfiles/4157/03CE6E7AF47B47F28BA01600B4F8F0CA.jpg[/IMG] |
RE: Front Leveling & 35" Tire FAQ
Has anyone heard how the Sandy River Enterprise 3" lift w/ rear add a leafs or w/ rear lift shackles? Are they causing any problems?
ORIGINAL: Timgco ANyone know the stock the height before the t bar crank? I haven;t found that listed anywhere. ORIGINAL: kr3whum1 you said shocks instead of the kit... can you show me a website that sells the shocks? |
Has anybody ever used or heard of the leveling torsion key lift that skyjacker makes for the H3?
ORIGINAL: asvinci Has anybody ever used or heard of the leveling torsion key lift that skyjacker makes for the H3? |
Hello all.....i have put on the cognito/blistien front leveling shocks on and the ride is far better than what i was attaining from the factory shocks....if someone is looking at leveling out the front end...i would suggest putting the shocks first then doing a level from the torsion....what i found out is after you have done a torsion bar twist in increase the level of the front end and have not put on the shocks prior , you will have to to another series of torsion bar adjustments after you put the new shocks on....why?.....i havnt a clue but the i did the torsion first...leveled out the ride....noticed a decrease in shock travel then installed new shocks...my ride was cockeyed and had to re do the torsion twist as i like to call it.
the H3 FRONT LEVELING SHOCKS by Cognito are excellent....i highly recommend them but do the shocks first then the torsion bar All the best.. SAMKELLY |
The correct front Bilstein shock number if doing a Torsion lift is F4-BE5-C153-HO. The proper rear Bilstein part number is F4-B46-1698-HO for stock height rear ends. Hope this helps.
I just leveled my truck with the skyjacker leveling kit and the mechanicrecomended new shocks because the oem ones were extended due to the kit. Everytime I hit a bump the truck bounces. What shock's should I buy and will they actualy help?
i decide to put 35" tires on my H3 but i have some doubts now on what to use !! i was gonna get Cognito Bilstein Hummer H3 Leveling Front Shocks!!! and besides that do i need anything else bump stops,lift kit,leveling kit any thing ?? I just found these they look gd quality any feedback and do i need to get leveling kit? http://www.trailduty.com/product_inf...roducts_id=778
Can we get some samples of before and after pics?
