Front End Float
Old Jul 12, 2007 | 08:23 PM
Tinseast's Avatar
Default Front End Float
I did the T-bar lift, 2 turns, 243/4" from wheel center to fender lip.
Had the front end aligned, install the Bilstien shocks. When driving
it feels like the front end is "floating". Similar to driving a pick-up
truck witha ton of gravel in the bed. Like there is reduced weight on the front wheels. Any suggestions? Thanks
Old Jul 13, 2007 | 12:28 AM
novasaigo's Avatar
Default RE: Front End Float
Floating? My front end got tighter but I kept the original shocks with just an extender.
Is the floating less control or more comfortable?
Old Jul 13, 2007 | 08:54 AM
Tinseast's Avatar
The feel of less control. The ride is a little spongy
Old Dec 16, 2007 | 08:47 PM
Hollywood Hummer's Avatar
Sounds like you have bad alignement
Old Dec 17, 2007 | 11:21 PM
tomp's Avatar
No, it's due to the fact you are no longer resting on the bump stops as it was from the factory. Best thing you can do is to add these to your shocks to reduce nose dive and body roll. Be warned that they may be hard to get over the shock mounts due to the h3 front shocks having that crazy mounting bracket on them. Worst case is you can split them, slide them over the shock rod and tie wrap them back together: http://www.trailduty.com/index.php?c...13_130_296_392
Old May 13, 2010 | 05:54 PM
BajaH3T's Avatar
Why not just add longer bump stops??
dkennel
Jan 13, 2012 08:03 PM
federicoiz
Nov 19, 2011 04:08 AM
jen813
Apr 12, 2006 06:07 PM
usmcman001
Feb 9, 2006 12:06 PM
falcons28fan
Jan 18, 2006 10:29 PM
