Front drive shaft rusted or stuck somehow
Old May 18, 2016 | 08:25 PM
Scott69's Avatar
Default Front drive shaft rusted or stuck somehow
Hello, 05 H2 front drive shaft rusted into the transfercase. I have it soaking in liquid wrench at the moment, I have tried prying, large hammer and air chisel. Any advice would be appreciated. Thank you, Scott
Old May 18, 2016 | 11:08 PM
aznplumber's Avatar
Heat it Up !
Old May 19, 2016 | 10:18 AM
flyday58's Avatar
I've had better luck with Blaster PB solvent on old rusty scooter parts. Works well after a 2-5 day soak.
Old May 19, 2016 | 11:24 AM
jsbihn's Avatar
Scott, both AZN and FLY are completely correct.
Liquid wrench wont really do much
If its frozen, you need to find a way to penetrate through the rusted bond, and the only way to do that is with heat or some dissolvent.
PB Blaster is good for that. Given there are some stronger things at NAPA that will get through it too.
Heat is the old reliable... but remember you could heat and tweak too much and break what you are trying to loosen up
Hope this helps
Old May 19, 2016 | 08:09 PM
Scott69's Avatar
Thank you everyone, I will give the pb blaster a shot first and use heat as a last resort.
Malcolm745
May 24, 2016 03:28 AM
flyinghunter
16
Apr 30, 2014 11:55 AM
jeffbyrd61
Apr 19, 2012 11:02 AM
adonatz
Apr 25, 2011 04:51 AM
Hummer007h2
Dec 30, 2010 10:25 PM
