Folding mirrors
Old Jun 7, 2010 | 10:40 PM
InfantryH2's Avatar
Default Folding mirrors
Mine don't fold from the inside... That common?
Old Jun 8, 2010 | 10:07 AM
VegasGuy's Avatar
One, yes. Both, not so much. Are you sure you are holding down the fold switch long enough and that the switch is not in the mirror adjustment position?
Old Jun 8, 2010 | 02:15 PM
InfantryH2's Avatar
how long do I have to hold it? When I do press it the mirror adjusts but doesn't fold...
Old Jun 8, 2010 | 07:16 PM
rotten's Avatar
Mine stopped working so I took them apart while I was at my inlaws. There was lots of rust inside them. Cleaned them up and used spray grease on them. Then Put them back on. Now the drivers side works good but the passenger side is still not working very good. So I plan to take it back apart and work it over now that I have access to my own tools. Youhave to take the door panel off to get them off.
Old Jun 8, 2010 | 09:01 PM
VegasGuy's Avatar
Only a couple of seconds and the left/right mirror selector switch needs to be in the middle position.
Old Jun 9, 2010 | 06:16 AM
balbright's Avatar
From what I have read, most pre 06' model probably won't work due to rust and circuit corrosion. Mine try to work but never fold. I need to do like others and take them off and try to clean them good. Still may not work, but i tried. I've also read that 06' and up are what people are replacing them with. Expensive though.
Old Jun 9, 2010 | 06:06 PM
VegasGuy's Avatar
If you are going to go through the work of trying to fix your mirrors, then you should read this post:
https://www.hummerforums.com/forum/s...56&postcount=9
It will refer you to a post with lots of pics on how to do the job and fix it right. Mine are still on my to-do list.
HUM DINGER
Sep 16, 2008 07:26 PM
Oman4x4
20
May 27, 2008 09:34 PM
gpete111
May 17, 2008 10:12 PM
davyo
Feb 2, 2008 01:33 AM
dizzy
Oct 24, 2007 02:33 AM
