Foglight access
Old Mar 15, 2008 | 05:28 PM
CWS's Avatar
CWS
Default Foglight access
Just a quick question; how do you access the foglights to replace the bulb ?
I took a quick look and there doesn't appear to be any access from the top, The ground is too cold, wet and snowy toget under the H3 to check if there's access from below. Do you have to remove the fender liner ?
Thanks, Cliff
Old Mar 15, 2008 | 06:22 PM
importkiller's Avatar
Default RE: Foglight access
I just pulled the fender liner back right behind the front bumper in the corner. You can pull it out enough to access the light...then it's easy. It takes me less than a minute now per light....the first time took forever until I learned the trick..
Old Mar 15, 2008 | 06:47 PM
rhill20's Avatar
Pretty much what Impy just said, when I put in the new bulbs that I bought off of him that's how I changed them. Slid my hand up between the liner and the bumper. First time is a bit of biotch but I think it's easier than removing anything.
Old Mar 15, 2008 | 07:26 PM
CWS's Avatar
CWS
Thanks guys, I knew there'd be the right expertise here.
Cliff
Old Oct 2, 2010 | 06:30 PM
Ole Yeller's Avatar
Yes, I agree, it's very easy to change the bulbs. However, I installed a cheap "better" bulb that was actually a big mistake. The bulb lasted a minute and then burst. Now my lens has debris inside of it and is cloudy. Does any body know how to remove the fog light housing? I would like to take it off and clean it up.
jmoffatt
Nov 2, 2011 12:42 PM
JDTDBD
Feb 12, 2010 09:16 PM
motley1987
Nov 1, 2009 01:42 PM
motley1987
Oct 25, 2009 09:13 PM
Koolaid
Apr 11, 2009 12:43 AM
