First Post!!
Old Aug 22, 2009 | 08:20 PM
twofish's Avatar
Default First Post!!
Hi, I am new to the Hummer brotherhood. I am grateful to have found this site.
I have a question already. Do the Luxury and the Adventure Package have the same gearing for normal driving? The reason I ask is I have bought a Luxury but want to upgrade to 285's on the tires but wanted to be sure that the final drive was the same.
If not will the Luxury model pull the larger tires okay?
Thanks,
twofish
Old Aug 22, 2009 | 08:36 PM
trip4219's Avatar
first off welcome to the forum! i just joined a month ago. i have an 07 with the adventure package and as far as i know the only real differences are that the adventures have the locking rear diff and a different transfer case ratio...you should have no problem runnin 285's from all the posts i've seen on here though...even the dealer i was at last week said most people that don't have the adventure package automatically put 285's on...hope this helps
Old Aug 22, 2009 | 09:13 PM
bflank's Avatar
If you do want the speedometer/odometer to be accurate you will have to have the PCM reprogrammed to account for the larger tires. The dealer can do it - if your wallet doesn't mind the hit. You can also get someone like PCMforless to do the reprogram and also adjust other parameters. A lot of forum members have used them and are happy with the results.
Old Aug 23, 2009 | 07:12 AM
twofish's Avatar
Thanks guys for the replies.
Who is PCMforless? I have not done a search to find them. I will do that as well.
Thanks again.
Old Aug 24, 2009 | 01:11 AM
Welcome twofish..........
Old Aug 24, 2009 | 08:49 AM
NJTEX's Avatar
Congrats on the new ride!
We just upgraded to 285 tires on our '06 Lux at a little over 70k miles and we are very happy!
The Adventure package has the same springs as the base and Lux but includes stiffer shocks. Now that we have about 2k miles of experience with our tire upgrade I think I know why stiffer shocks were specified and I'm looking to upgrade our shocks too. With the heavier tires, there's now more rear axle "stuttering" through potholes/bumps at higher speeds. You may want to keep this in mind too depending on your driving conditions.
At this point I'm still researching what's better, OEM Adventure package shocks or Bilstein Yellow HD shocks.
Old Aug 24, 2009 | 12:11 PM
BLACKH3T's Avatar
If it is a '09 you will have a locking FRONT differential if it has the Adventure package.
importkiller
48
May 13, 2008 10:24 PM
lordlang
Apr 21, 2008 09:38 AM
DIRKD
22
Aug 3, 2007 03:10 PM
dot21
Aug 3, 2007 03:03 PM
Lawdawg
Jun 27, 2006 04:17 PM
