Finally got a "snip"
I swapped mine with the antenna on my wife's Pontiac Solstice. Two inches shorter made all the difference. Only problem is the mount. the H3 expects a male connection on the antenna, not female like the rest of GM. I actually had a few adapters laying around to circumvent this.
I found a short rubber antenna at Pep Boys to put on the Solstice later.
I do not care for the long thin stack antennas. For the life of me, I can't figure out why any vehicle would still come with those.
I ordered a AMI 21" stubby antenna from hummerpartsclub.It comes with the exact adapter you need for the H3.
It comes in even shorter lengths, but I thought anything too short would look kind of silly.
Here's a link for anyone interested.
http://hummerpartsclub.com/mm5/merch...ry_Code=AMI_H3
EDIT: That link is to the black stubbies, but they have numerous other options here: http://hummerpartsclub.com/mm5/merch...ry_Code=AMI_H3
I think I'm actually going to order one with the lasered black flames and I'll put the black one I have now on wifey's Tahoe.
Mr. Vader is right....The antenna it "tuned" to the radio and that's why it looks the way it does. When you buy a stubby, the entire length of the optimal antenna is wound into the new stubby thus making the overall antenna shorter but still containing the same amount of wire for proper reception. You should notice a decrease in reception now that you've done your dremel deed, if not in strong local stations then in marginal ones. Length DOES matter! [sm=nothatway.gif]
ORIGINAL: RealJeep
ORIGINAL: D VADER
Antenna length is paramount to good reception. Do you notice any loss?
P.S. I have a standard 9' Door and my antenna doesn't rub. Did you guys lift your H3?
[sm=vader.gif]
