EXTRA BATTERY
Old Dec 11, 2007 | 10:58 AM
kdec19's Avatar
Default EXTRA BATTERY
Has anyone added a second battery to their hummer h2. If so where and how much did it set you back!!
I figure alittle winching in the dark and one battery will be a little weak!![X(] even if the engine is running!!! any good ideas.
Trying to get set up to go in the Maine woods!!!
Old Dec 12, 2007 | 09:24 PM
kouvelis888's Avatar
Default RE: EXTRA BATTERY
i have added 2in the back and 1 under the hood all 3 optima yello tops there bout 200 each and i put the to in the back above the wheel well on the in sid of the truck
Old Dec 16, 2007 | 10:29 PM
Calgary's Avatar
Two red top Ultima batteries will fit (snugly) in the location of the original battery.
Take out the battery tray and use a dremmel to take the edge of the tray off so that the tray is no just a flat pan. Put the first battery in lengthwise so that the negative terminal on top is towards the front of the truck and so that it fits tight against the fender. Put the next battery in next to it in exactly the same fashion. Hook original battery cables to the side posts of the battery that is closest to the engine. The negative cable should fit but you may need to take the cover off of the fuse box to get the positive cable to reach. Once they are hooked up, use about 6 inch cables to connect the top posts of the batteries in PARALLEL! Hook the positive to the positive and the negative to the negative. The two cables will be parallel to each other.
The two batteries fit in there so well that I didn't even need any way to hold them down. They wedge in there perfectly!!
Good Luck
Old Dec 17, 2007 | 10:16 AM
HumminNBoatin's Avatar
Calgary,
Do you have pix of your install?
Old Dec 18, 2007 | 10:59 PM
dizzy's Avatar
What,s the reason for running two batteries? Would the voltage be the same?
Old Dec 27, 2007 | 08:14 PM
got any pic of the instal and can i do the same thing with 2 yellow tops
Old Dec 28, 2007 | 07:32 AM
noclrnce's Avatar
Ive been eye ballin this :http://www.wranglernw.com/pc-6377-84...2000-2006.aspx
Old Dec 29, 2007 | 09:11 PM
Calgary's Avatar
Sorry, I have been away on holidays. I'll take a picture when I get home on Wednesday and post it. Sorry it took so long.
g
Old Jan 1, 2008 | 03:00 PM
dont spend 500$ on that dumb *** try. ill have pic up in the next day or to cuz its snowing alot out here in chicago.
Old Jan 11, 2008 | 12:52 AM
here is the pic of the battery instal
