Engine starts and stalls till engine temp warms up then it will stay running.
Engine like floods out till temp of motor gets warm. Any help with this would be great. My trouble codes that came up are 601, 300, 240, 135 ,030 and 130. Don't know where to start but much engine light is off also
2006 H3 3.5 engine with 256,500 miles .
240 is a turbo code. 420 makes more sense.
Clear codes, and start over. Make sure battery voltage is good, with clean secured terminals, then get ready to check wiring and connectors. GL
P0601 CHEVROLET Possible Causes
- Faulty Powertrain Control Module (PCM)
- Powertrain Control Module (PCM) harness is open or shorted
- Powertrain Control Module (PCM) cicuit poor electricl connection
- Low battery voltage
P0300 CHEVROLET Possible Causes
- Faulty spark plug (s)
- Faulty ignition coil (s)
- Clogged or faulty fuel injector (s)
- Intake air leak
- Fuel injectors harness is open or shorted
- Fuel Injectors circuit poor electrical connection
- Ignition coils harness is open or shorted
- Ignition coils circuit poor electrical connection
- Insufficient cylinders compression
- Incorrect fuel pressure
P0420 CHEVROLET Possible Causes
- Faulty Three-way Catalyst Converter Bank 1
- Exhaust Tube
- Intake Air Leaks
- Faulty Oxygen (O2) Sensor
- Faulty Fuel injector(s)
- Leaking Fuel Injector (s)
- Faulty Spark plugs
- Improper Ignition Timing
- Faulty Engine Control Module (ECM)
- Dirty Air Filter
P0135 CHEVROLET Possible Causes
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
P0030 CHEVROLET Possible Causes
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit
P0130 CHEVROLET Possible Causes
- Faulty Front Heated Oxygen Sensor Bank 1
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
Mine is doing something similar and it's intermittent.
My 2006 H3 has a total of 212000 miles but a new replacement engine was put in at 95000, so this motor has about 107000 miles on it..3.7 L 5-cylinder. No modifications.
I warm mine up usually about 3 minutes or so. When I leave my house and stop at the first stop sign, if I slow down at a normal or quick speed, it will stall out the first time, then the rest of the trip, it's warmed up and never happens again.
If I slow down at a slower than normal speed at the stop sign, it won't stall.
Anyone know why stopping slower makes it not stall and then once it's fully warmed up it does not stall at all.?
Sorry, if this is considered hijacking someones thread, I just did not think I should create a whole new thread for such a similar question.
As always thanks!
As always thanks!
As always thanks!
As always thanks!
OP has a short.
Start with the basics. Clean your MAF and throttle body. The dirtier the throttle body gets, the lower the idle drops until it begins to cause a stalling condition. I hadn't cleaned mine in awhile until Saturday. I started noticing that when I came to a stop my oil light came on indicating low oil pressure. I noticed I was idling below 500rpm and almost stalling. Took 20 minutes to clean things up, idle is back up to around 700rpm and things are back to normal.
Thankyou all for tips . I'm gonna let Gm dealer run diagnosis on it and go from there. This all started a couple weeks after a shop changed intake gaskets , and cleaned out throttle body too. I called shop and asked if maybe a wire got pinched off cause cold start issue started. They didn't offer to look at it either.
Boy
May 14, 2017 03:36 PM
