Engine not starting
Old Oct 15, 2010 | 08:27 PM
thedave8's Avatar
passlock antitheft failure.....cutts off fuel injectors ......cranks but no start......leave key in on position til "padlock" stops blinking..then turn key off and start it.....replace ig. switch/passlock
Old Nov 12, 2010 | 12:36 PM
puresuccess's Avatar
Was changing the ignition switch successful? I have an 07 H3 that is doing something very similar. Turns over but won't start. Wait 15 mins and starts right up. I've got a friggin 30k truck parked. Has GM put out a service bulletin on this. New member here, I appreciate any assistance.
Old Nov 14, 2010 | 10:49 AM
thedave8's Avatar
Yes , mine only had 37k on it and passlock went bye bye......if yours is doing what i described above, yup it will fix it. They replaced the ignition switch and i am good to go. No bulletin i am aware of, but the dealer knew excactly what it was when i told 'em.....
Old Nov 14, 2010 | 11:30 AM
drtom's Avatar
Banned
Default Life or death
its not hard to visualise how many ways this problem could be a LIFE OR DEATH situation.
i think gm should put out a permanent fix and then a better theft alarm
Old Nov 15, 2010 | 08:57 AM
thedave8's Avatar
I agree 100%!!!!!!
Old Nov 15, 2010 | 09:06 AM
drtom's Avatar
Banned
Default one step further
the first "wrongful death"lawsuit will bring on the fix
1.the lady keeps turning the key,,while the guy with the pipe decides to come in,,,
2.
Old Jan 4, 2011 | 05:55 PM
KevMan05's Avatar
anyone have a link or part number!? i need one too... also does the computer have to be reset or anything or just plug and play?
Kevin
Old Jan 4, 2011 | 06:16 PM
KevMan05's Avatar
is this it?
ACDELCO Part # D1462G {#15795321, 15795322, 15795324, 19149942, 89060589, D1403G, D1405F}
HOUSING,IGN & START SW w/4-SPD A/TRANS(M30) or STRG COL(NP7-EXPORT); HAS SHAFT LOCK, INCLS PASSLOCK SENSOR, SWITCH; w/o RIGHT HAND DRIVE(RHD)
HOUSING,IGN & START SW w/5 SPD M/TRANS(MA5) or TILT STRG COL(N33) or STRG COL(NP7-EXPORT); HAS SHAFT LOCK, INCLS PASSLOCK SENSOR, SWITCH
Old Jan 28, 2011 | 01:13 AM
KevMan05's Avatar
okay guys... really need some help on this passlock sensor! I changed it.. the truck would not start.. waited 10 minutes.. started up.. turned it off.... wont start.. 10 minutes.. it started.. Put the old one back in.. works fine.. and once in a while it gives a problem.. so after I put the new one in, do i need a ECU flash or something so the truck can accept it?
HEEEELPPPPPPPPPPPPP!!
Lms Scratch
Dec 17, 2014 02:30 AM
Ghost Rider
Aug 22, 2012 02:43 PM
cqaurich
Sep 30, 2010 07:50 AM
Big D
Aug 22, 2009 06:44 PM
hummer
Feb 6, 2008 11:24 AM
