Engine compartment swap question
Old Oct 25, 2015 | 11:27 AM
jntfj80's Avatar
Default Engine compartment swap question
Ok...I found something I might want to attempt. But need to know, if it will fit.
I measured the engine front to back, the width, the height at the rear from top to bottom of the rear oil pan, and the height at the front from top to bottom of oil pan
from fan hub (w/o fan blade) to flex plate [------33"--------]
width [------37"--------]
depth at rear top to bottom of oil pan 37"
depth at front top to bottom of oil pan 34"
Right at about 500lbs
These are pretty close, but approximately with a tape measure.
Any thoughts? I am ready to pull the trigger if it will work. GM motor, I'm purposely not saying the exact engine it is right now...because, I don't want the blah-blah-blah. But, I think it would be an awesome build.
Old Oct 25, 2015 | 01:58 PM
happythree's Avatar
hard to figure what you want based on ????
good luck
Old Oct 25, 2015 | 02:51 PM
jntfj80's Avatar
I'm just simply asking will an engine of that basic size...squeeze in under the hood of an H3/H3T.
Old Oct 25, 2015 | 03:36 PM
650Hawk's Avatar
The secrecy is kinda counter-productive; not sure why it's necessary. Not to mention that any engine is not simply rectangular, nor is an engine compartment, so a few basic measurements mean very little. If you want to know if a certain engine will fit, ask; if it'll fit, it's likely to have been done (or attempted) and you can get some good info/pros/cons from those with experience.
Old Oct 25, 2015 | 04:10 PM
happythree's Avatar
physical fit is one thing, getting it matched to the comp/electrical, well???
thats the big job
actually i dont remember ANY real swaps posted here
Old Oct 25, 2015 | 07:02 PM
skeeter's Avatar
I have seen a couple of LS swaps done on the H3/T, but I want to do a diesel swap on mine.
Old Oct 26, 2015 | 05:54 PM
jntfj80's Avatar
Not trying to be secret. Ok, so here is the deal. I have in my hands on 3, yes 3
Post-bankruptcy GM auction engines. You had to bid on a semi truck load of sometimes junk, but not allows and you got what you got. Well, there was lots of stuff but, there were three 4.9liter V6 duramax turbo diesels all set-up with wire harnesses, Bosch ecm's, and ready to be bolted to 4l80e transmissions. So recently, the old 3.7L 5 cylinder seized, hmmm....is this the time to see what a V-6 duramax would have been like in an H3T. I don't know, I'm kicking it around. There seems to be enough work arounds out there for the BCM/TCM it might possibly work, and remain operational(the truck) inside as if a 3.7L was still under the hood.
Old Oct 26, 2015 | 06:42 PM
mr.spooky's Avatar
nice score
Old Oct 26, 2015 | 06:57 PM
happythree's Avatar
make it work,youll be a hero!!
Old Oct 27, 2015 | 12:43 PM
650Hawk's Avatar
Sounds cool. You might want to check in over at Pirate4x4.com, they have a Hummer section that has a number of swaps/builds.
7ducati
Apr 1, 2014 11:49 AM
needabiggerhouse
Nov 28, 2012 06:34 AM
rickey.mclester
17
Apr 30, 2012 11:28 AM
ukpaul
Feb 29, 2012 06:37 PM
mountainbiker
Feb 6, 2007 05:44 AM
