Electrical issue or ECM or ?
Old Nov 8, 2020 | 12:43 AM
WhiteWolf's Avatar
Default Electrical issue or ECM or ?
I need some help with an electrical issue – I had a P0788 – (3-2 Downshift Solenoid).
I was about 200 miles from home and just manually up shifted from a dead stop when needed (basically when pulling out of a gas station) The radio played the entire way home.
Took it to the transmission shop, they said the solenoid shorted and replaced it.
Driving home from the Trans shop, the radio worked. The next day my radio would not come on (aftermarket double din with the OnStar/door chimes harness from Crutchfield / non-Monsoon), then I noticed my grille lights were not coming on. I checked the #13 fuse, and it was good, the climate control works (it is on the same fuse).
It’s odd to me that the climate control works, but the other 2 items on the fuse don’t.
PCM Reset didn't work, I touched battery cables together for 60 seconds then left unhooked for about 15 minutes and still didn't get the radio or the grille lights working.
Sounds like a shorted wire somewhere? but I have no idea where to start looking… or which (ugh) wiring harness to trace. Could it be one of the controllers somewhere?
I have replaced the battery terminals last year with good ones and they are nice and tight.
I’ve read about the drain tube issues and do have that, but it has been minimal water in the passenger floor. The PO silicone the sunroof (mostly anyway, not a great job of making it completely water tight) There was no rain for the week that the solenoid went out and the time I got it back.
If it is the ECM who is better PCMofNC or FS1inc? I have had the key fob’s and keys done by a local locksmith, so I don’t know if they are programmed to the original VIN or if I will have to have them come out and reprogram if I get a replacement ECM
It’s a 2007 H3 base / 3.7
WhiteWolf
Nov 9, 2020 11:03 AM
WhiteWolf
Nov 7, 2020 03:03 PM
moses42ak
Sep 12, 2011 03:10 PM
LastLineOfDefense
Oct 27, 2010 01:24 PM
