electric fan?
Old Jan 13, 2016 | 06:42 PM
happythree's Avatar
Default electric fan?
if i do a new water pump it would be a good time to ditch the fan and go electric.
can i get an update on brand and wiring needed to do that.
any comments welcome...
Old Jan 13, 2016 | 09:45 PM
rsc's Avatar
rsc
James at Supermodulation over on the Coly/Canyon forums has a complete e-fan setup. So does PCM of North Carolina (the old PCM4Less). I built my own system, but remember it does need to have a high cfm rating, e-fans are not as efficient as the mechanical fan although it frees up hp and mpg's.
Old Jan 14, 2016 | 07:58 AM
You have a 2010? I think so, but I can't remember.
The PCMofNC Efan for 2008+ models is controlled by the PCM, so you need a PCM tune to patch that control in. Wiring is to specified wires feeding specified pins under the fuse block. There is nothing to say you can't use the 2006-7 Efan kit, it is controlled through a sensor in a CNC fitting spliced into the lower radiator hose, then you do not need a PCM tune, and it too taps into the harness connections under the fuse block.
I have had mine for gonna be 6 years in Feb, I got one of the very first kits when released. Works flawless so far. It does make some noise when on as rsc points out, they have to move a bunch of air when called for. Between say December and mid March, it might actually turn on like a handful of times, usually when sitting in a drive through line/idling at length.
Old Jan 14, 2016 | 11:12 AM
happythree's Avatar
thanks guys, im curious what those wires do?
are they just for power?
ok now, i read pcm instructions.
older 07 model costs more??
Old Jan 15, 2016 | 06:13 AM
rsc's Avatar
rsc
yeah, the 06-07 have the inline temp sender that adds a buck or two to the price. Either way would be a good setup.
Nxsov180db
32
Dec 18, 2012 11:34 AM
buzzwohl
42
Jul 16, 2012 05:15 PM
hummerjim
May 29, 2008 04:38 PM
Linus Gump
Oct 20, 2006 10:40 PM
droptopvette
Jun 3, 2006 11:56 PM
