Electric fan
Old Oct 19, 2006 | 08:26 PM
Linus Gump's Avatar
Default Electric fan
Has anyone thought of replacing thier stock fan with an electric one? It would free up some horsepower, even when it isn't engaged it still has drag on the system. I'm just curious what others think of the idea.
Old Oct 19, 2006 | 09:49 PM
blackstangs281's Avatar
Default RE: Electric fan
Have not heard of anyone trying that yet. I would think it would work fine, and free up some hp. The only thing is if you need warranty work, I don't think the dealer warm up to the idea.[&:]
Old Oct 19, 2006 | 10:57 PM
ZOO's Avatar
ZOO
I would like to install one on mine. However, I know the warrenty would not go with it.
Old Oct 20, 2006 | 01:15 AM
Linus Gump's Avatar
Why would there be warranty issues? Unless the thing overheats because the fan doesn't come on, the only thing you are doing is removing the stock fan and shrowd. That shouldn't cause a warranty issue.
I did this on an old Scout I had. The problem there was the mounting system was a poor design and it tore up the radiator, but it freed up power, plus made the heater work better since the fan wasn't overcooling the coolant in the radiator between thermostat openings.
Old Oct 20, 2006 | 12:43 PM
CerberusSVT's Avatar
ORIGINAL: Linus Gump
Thats not a bad idea, but I'd probably do it more based off the fact that I hate how the fan on this truck is so damn loud and that it seems to run alot more and alot harder than it should (I sound like a damn Chinook helicopter trying to get out of the parking lot on cold starts!)
Old Oct 20, 2006 | 07:14 PM
HummerGuy's Avatar
Where would you put the temp sensor, and where would you get the power from? Is there a kit for this? I likey!
Old Oct 20, 2006 | 09:40 PM
ZOO's Avatar
ZOO
Who wants to be the first to modify their rig?
Old Oct 20, 2006 | 10:12 PM
Linus Gump's Avatar
The one I put on my Scout had a probe that went through the radiator between the tubes. You put it close to the inlet side of the radiator. It came with all of the wiring, and all you had to do was hook it to the battery. If you wanted, you could also hook it to a switch on the dash so you could manually turn it on before the engine heats up if you think it might, such as climbing a hill with a trailer. The biggest problem was a poor system of mounting the fan to the radiator which caused the radiator to develope small pin hole leaks. If I can find one with a better mounting system, I am totally game for doing it again.
Old Oct 20, 2006 | 10:40 PM
HummerGuy's Avatar
I'm definitely up for it.
Nxsov180db
32
Dec 18, 2012 11:34 AM
buzzwohl
42
Jul 16, 2012 05:15 PM
CHP
Jun 8, 2011 07:55 AM
hummerjim
May 29, 2008 04:38 PM
droptopvette
Jun 3, 2006 11:56 PM
