E Break Stuck
Old Jun 15, 2017 | 06:57 PM
Synthetickiller's Avatar
Default E Break Stuck
Long story short, I am in the process of changing my oil & the e break pushed all the way back when trying to engage it.
It's now stuck.
I'm going to get a look at the underside & see what is going on with the cables.
Any ideas how to fix this?
Edit: E Break line(s) look broken. I will upload pics in a minute.
Picture here:
E-break line to passenger side rear is cleaved. The driver's side line is pull taught.
Ideas to disengage?
Looks like dry rot. I am not in "need" of using these since it's flat a board here, but it's something that needs to be fixed before the next oil change. Easy procedure?
Final update to this issue.
The vehicle does not have it's e-break engaged. It is showing it on the dash, though. The H2 moves in reverse & forward without any resistance. I have not taken it out on the road.
I can live without the cable working (breaks work, so that's all that matters). How do I fix the e-break light/e-break?
Old Jun 16, 2017 | 08:04 AM
citiboy's Avatar
Check your e-brake pedal, it might be a little push down and trigger the switch, while pulling the e-brake release handle, push the e-brake pedal up and check the light.
You should do the e-brake cable mod that i did. This mod relocates the cable over the axle so it won't get caught on anything.
Old Jun 16, 2017 | 08:52 AM
Thanks man. That's a really good idea.
I found a few youtube videos showing how to get it unstuck if that method won't work. I will try it later when I have time. As long as the vehicle can go from point A to point B, I'm set for now.
I'm going to replace both, since they are really dry rotted. Are these considered an acceptable replacement?
Rear Left
Rear Right
Old Jun 16, 2017 | 09:00 AM
citiboy's Avatar
You said the e-brake we're not engaged, so the only culprit there is the e-brake pedal that loses the tension because of the broken cable. I only replaced mine with oem so i don't know about that cable, looks like a good quality and it's not made in china and that's a plus. lol.
Old Jun 16, 2017 | 04:04 PM
I was able to pull the e-break back to it's proper position. It'll stay that way for a while.
I will probably pick up those 2 cables soon.
Thanks again for the help.
Old Jun 16, 2017 | 04:14 PM
citiboy's Avatar
Did the brake warning light in the dash turned OFF?
Old Jun 16, 2017 | 05:51 PM
Yep, it's off.
nncanfarelli
Aug 4, 2019 09:27 PM
HumRluvR
May 31, 2016 07:53 AM
HummerGuy
27
Jul 22, 2007 01:14 AM
Dennis
May 4, 2007 12:15 PM
importkiller
22
May 22, 2006 03:01 AM
