DRL and Turn Signal wire locations and colors
Old Apr 11, 2017 | 04:58 PM
Default DRL and Turn Signal wire locations and colors
Hello OEM or GM wire schematic gurus, I need some assistance.
I'm looking for the wire location and colors for the following.
DRL wire: have new LED driving lights from Australia for the ARB bumper that have a DRL feature j would like to use instead of the headlights. So , I need to disable the DRL headlights and power the DRL feature in the new driving lights. What wire or wires do I need and where are they?
Turn Signal wire: have new LED signal lights from Australia that have a very bright corner light on them. I would like to wire them up to illuminate the left or right when I use my signal (like the Cadillac's do). I need to tap into the wire before the flasher circuit so I can have constant light when the turn indicator is used.
2010 H3 Alpha or H3T Alpha (should be exactly the same)
Colors and locations are the key points I need. I can wire pretty much anything but I need to know where to get the "signal" from.
Thanks in advance.
Old Apr 11, 2017 | 09:12 PM
happythree's Avatar
have you studied the detailed wiring info in the svc manual and not found it?
i can look there when i get time.
i have the 2009 stack of books that are a pain to leaf thru and just the 07 downloaded. its easier and i see stuff relating to what you want in the lighting pdf.you might look there
Old Apr 11, 2017 | 10:37 PM
Kkneat's Avatar
Sorry if this against the rules but this website has a lot of schematics on it for the H3 https://schwarttzy.com/h3-hummer/
Old Apr 12, 2017 | 06:57 AM
Thanks, I have all the schematics for the H3/H3T wiring on file.
I need to know which wire to use and where it is to achieve my goals.
Not an electrical engineer and I don't want to adversely affect my BCM.
Old Apr 12, 2017 | 04:12 PM
happythree's Avatar
pretty hard to figure without knowing what the "new" stuff needs.
Old Apr 13, 2017 | 05:36 AM
Chimpy's Avatar
I am interested in just the disable part of the story.
Old Apr 13, 2017 | 11:01 AM
happythree's Avatar
should make new topic but to dis the drl, pull the drl fuse
Old Apr 15, 2017 | 06:08 PM
WR3NCHE4D's Avatar
Don't quote me on this. I would have to look into it but, I think the BCM controls the DRL's by dropping the voltage to the high beams or running them in series. A DRL module doesn't exist. There is no wires for the DRL's, only headlight wires. When I get some time I will look into it. To disable the DRL's you need to reprogram the BCM and turn them off using the GM TECH 2 scan tool.
Anyone want to chime in to confirm?
Old Apr 15, 2017 | 06:23 PM
Broken Halo's Avatar
Maybe that's why I blew my BCM when I tried to re-route into my parking lamps.
Old Apr 15, 2017 | 06:59 PM
happythree's Avatar
