Driver Window Switch Button Fractured Off
Old Oct 21, 2013 | 11:39 AM
BlueH3's Avatar
Default Driver Window Switch Button Fractured Off
My 2009 window switch driver side fractured off. Anyone replace just the button possibly? Do I have to remove the entire switch? Do they sell just the button somewhere?
Old Oct 21, 2013 | 12:52 PM
digglesworth's Avatar
I have an 06 and the lights in the two front window switches are out. I asked the local dealer about it and they said those things come assembled as a complete unit. So no replacing any individual pieces. I would say try some junkyards to see if you can find one or maybe eBay.
Old Oct 21, 2013 | 02:07 PM
wfturner's Avatar
You can change out the bad bulbs in the driver side door window switch.
Just gently pry up the entire switch assembly and unplug harness. Remove (untwist) the bulbs and remove blue cover from bulb and put blue cover on new bulb, reassemble
You can the exact bulb and base here,
Five 5 Bulb for 2005 2010 Hummer H3 Heater A C Controls Window Switches Mini | eBay
BlueH3-
Unless you can find a junk yard switch assembly, no you can't get just change out the one button.
You will need to replace the entire assembly. Check model year before ordering
SWITCH. Door and End Gate Electrical. DOOR TRIM/SIDE FRONT. 2007 Hummer H3 # 15920923
DocOlds turned me onto these exploded view schematics
Attached Thumbnails Driver Window Switch Button Fractured Off-door-panel.jpg
Old Oct 21, 2013 | 04:52 PM
THAT'S AWESOME!!! However, that link goes to a seller that is "on vacation til Dec 31, 2015 and not processing orders"... I'm gonna see if I can find others.
Old Oct 21, 2013 | 06:16 PM
wfturner's Avatar
Check my latest PM, I found a guy in the county [sic]
Old Dec 1, 2013 | 07:39 PM
switch doctor's Avatar
Not sure but if you end up needing one let me know Hummer H3 Window Switch
Old Dec 1, 2013 | 08:50 PM
BlueH3's Avatar
Thanks I worked it out and bought a pass side and swapped the pull up/down switch....cheaper.... but a still a damn expensive just for the once little pc.
Mr_Fulano
Mar 11, 2022 11:40 AM
hummerhack
Dec 17, 2014 02:25 AM
ukpaul
Jan 5, 2009 07:56 PM
augustin01
Jun 18, 2008 06:07 PM
heavyD
May 14, 2008 04:52 PM
