driver window
Old Jan 21, 2008 | 08:40 PM
tony1969's Avatar
Default driver window
I have a 04 H2 and the drivers window squeaks when you put it up and down. Sounds like the rubber on the outside or the inside. Maybe I can lube the rubber some how?
Old Jan 21, 2008 | 08:59 PM
ZYNE's Avatar
Default RE: driver window
Umm .. you'll get lube all over the window ..
Old Jan 22, 2008 | 07:45 AM
tony1969's Avatar
Thats what I thought too. Just not sure what to do. Not even sure if it's the rubber. But the squeak is making me crazy.
Old Jan 22, 2008 | 10:05 AM
You might check that the plastic trim around the window is seated properly. I have not been inside an H2 door panel but in some of my other cars the glass can get slightly out of track and not roll up straight. Does your window seat properly when you roll it up.? Do you notice any movement sideways, other than a smooth straight up motion to the top? My guess is either the window trim or the glass itself is out of alignment and needs to be adjusted/repositioned.
Alukavi
Dec 28, 2020 09:22 AM
hummerhack
Dec 17, 2014 02:25 AM
potroast
Dec 14, 2013 11:27 AM
jhpulley
Nov 27, 2010 12:21 AM
